Results 1 to 4 of 4
  1. #1
    New Member Reputation: 0
    Join Date
    Sep 2010
    Posts
    2
    Rep
    0
    Question Enigma II - Wireless Card
    Hi, just installing the drivers for an Enigma II I recieved yesterday; within the NBLB2 Driver CD there are three options for the wireless drivers; Intel, Realtek and Atheros.
    Which one is the reccomended one for installation, and what's the difference between them please? Any help is much appreciated
    Bharat.
  2. #2
    Master Reputation: 2408
    Join Date
    Jul 2010
    Location
    Newbury
    Posts
    4,954
    Rep
    2408
    Ok you got me, i have no idea what make it will be, if i had to guess i would say Intel. Call us on 0844 499 4000 tomorrow for a definitive answer if no one chirps in here first.
    I dont work for PCS anymore, fix it yourself!
  3. #3
    Member Reputation: 4
    Join Date
    Sep 2010
    Posts
    50
    Rep
    4
    Yep .. its intel (atleast for mine).. I installed all the drivers and it worked with the Intel one
    Enigma II i5 450M
    15.6" (1920x1080) Super Clear
    4 GB DDR3 1333MHz Ram
    1 GB ATI HD 5650
    500 GB WD Balck(7200 RPM)
  4. #4
    Master Administrator Reputation: 2790
    Join Date
    Jul 2010
    Location
    Huddersfield
    Posts
    4,892
    Rep
    2790
    They're normally Realtek. In Device Manager when you right-click on the adapter and install the drivers, you can browse from CD. This way it will select the right drivers automatically.
    These forums are not an official channel for support, if you have a problem with your machine please ensure you notify us through our official channels.
    These are through our website mail system or by calling Tech support direct on 0844 499 4000.
    Alternatively for general enquiries email enquiries@pcspecialist.co.uk, to see current waiting times at our call centre click here.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© PC Specialist Ltd
