Results 1 to 3 of 3
  1. #1
    New Member Reputation: 0
    Join Date
    Apr 2012
    Posts
    1
    Rep
    0
    Building a Gaming Rig, help!
    Hello there.
    I am currently planning to buy myself a new Gaming PC however, as I have little knowledge of hardware and the like, I've decided to ask you knowledgeable forum-goers for assistance.
    - I want a gaming rig that will last for a few years with little to no upgrades and will run most/all current PC games (Shogun 2, TOR, Crysis 2, Guild Wars 2, etc etc) aswell as games in the next few years with little in the way of problems.
    - Sadly, I'm running on a limited budget so won't be able to buy outright so will be getting this PC on finance. I'm limited to being able to pay about £100 a month.
    And that's all there is to say really, I look forward to seeing the replies. ^^
  2. #2
    Grand Master Moderator Reputation: 5428
    Join Date
    May 2011
    Posts
    7,275
    Rep
    5428
    Are you looking for a full tower case (some are pretty big) or a good sized mid tower? Just helps to decide which case would be best.
    CM Storm Trooper Pictures
    CM Storm Trooper - Intel I7 2600 @3.4 - Asus P8Z68 V Pro - 16Gb Kingston Hyper X Genesis 1600Mhz - 2GB EVGA GTX 680 Superclocked - Corsair HX1050 - Noctua NH-D14 - 120GB Corsair Force GT SSD - 1TB WD Caviar Black - 2Tb WD Caviar Green - Asus DX - Lamptron FC 8 - NZXT HUE LED Controller - Tritton Ax Pro - 2X IIyama 24Inch - CM Storm Quickfire TK - Razer Imperator
  3. #3
    Join Date
    May 2011
    Posts
    7,275
    Rep
    5428
    This spec comes to £38.36 per month,
    Ya could up some components if you wanted to spend more, however, I don't think you need to.
    CORSAIR CARBIDE SERIES™ 500R WHITE MID TOWER CASE you can read about this case here
    Intel® Core™i5 Quad Core Processor i5-3550 (3.3GHz) 6MB Cache you could jump up to the i7, but i'd stick with IVY bridge cpu's
    ASUS® P8Z77-V: PCI-E 3.0 READY, WIFI, SLI, CROSSFIREX I wouldn't lower this mobo personally,
    8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB)
    3GB AMD RADEON™ HD7950 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable really good gpu, you could up this to the 7970 or a gtx 680, but personally I think this is a good sweet spot, it also runs pretty cool and uses low power, with this rig, you can also add another 7950, with no need to upgrade the power supply, giving you a nice boost in performance, in the future, if you wanted to ofcourse.
    Memory - 1st Hard Disk
    120GB INTEL® 330 SERIES SSD, SATA 6 Gb/s (upto 500MB/sR | 450MB/sW) mid to high range ssd, will sure you well as a boot drive, and speed up ya system well,
    2nd Hard Disk
    2TB WD CAVIAR BLACK WD2002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm) really good for all ya games to go on
    1st DVD/BLU-RAY Drive
    CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£69) perfect mate
    SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE INTEL CPU COOLER (£19) Again perfect for ya needs, no need for anything higher.
    Network Facilities
    NO OFFICE SOFTWARE
    Quantity
    1
    Price: £1,255.00 including VAT and delivery.
    Configure Here: http://www.pcspecialist.co.uk/comput...ivy-bridge-pc/
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© PC Specialist Ltd
