£1400 (advice on HDD + sound card + gfx)
InWin CENTINAL BUC BLACK GAMING CASE
Intel® Core™i7 Quad Core Processor i7-3820 (3.6GHz) 10MB Cache
ASUS® SABERTOOTH X79: SOCKET 2011, R.O.G
16GB KINGSTON HYPERX GENESIS QUAD-DDR3 1866MHz X.M.P(4 x 4GB KIT)
3GB AMD RADEON™ HD7970 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
Free Item
Free Item
FREE DIRT SHOWDOWN GAME with any AMD 7000 Series GPU!
Memory - 1st Hard Disk
2TB 3.5" SATA-III 6GB/s HDD 7200RPM 64MB CACHE
1st DVD/BLU-RAY Drive
INTEL SOCKET LGA2011 STANDARD CPU COOLER
Network Facilities
Genuine Windows 7 Home Premium 64 Bit w/SP1 - inc DVD & Licence
Grand Master
whats it for dude? gaming?
looks slightly out of balance.
CM Storm Trooper Pictures
CM Storm Trooper - Intel I7 2600 @3.4 - Asus P8Z68 V Pro - 16Gb Kingston Hyper X Genesis 1600Mhz - 2GB EVGA GTX 680 Superclocked - Corsair HX1050 - Noctua NH-D14 - 120GB Corsair Force GT SSD - 1TB WD Caviar Black - 2Tb WD Caviar Green - Asus DX - Lamptron FC 8 - NZXT HUE LED Controller - Tritton Ax Pro - 2X IIyama 24Inch - CM Storm Quickfire TK - Razer Imperator
Yeah gaming, what should I change about it? RAM?
8gb RAM might be enough for gaming (that's what I went for anyway on mine). Also if you have a 1400 budget you could get a lovely new Nvidia card like a 670 or 680.
Edit: I'd also bump up to the silver warranty it's only an extra £5.
COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE // Intel® Core™i5 Quad Core Processor i5-3570K // ASUS® P8Z77-V // 8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz // 2GB NVIDIA GEFORCE GTX 670 // CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE
For lots of pics click here
Ok. So is there much difference in the 680 and the rad 7970?
Super Star
For 1400 I would get this
NZXT PHANTOM 410 BLACK GAMING CASE
Intel® Core™i7 Quad Core Processor i7-3770 (3.4GHz) 8MB Cache
ASUS® P8Z77-V: PCI-E 3.0 READY, WIFI, SLI, CROSSFIREX
8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB)
Free Item
120GB INTEL® 330 SERIES SSD, SATA 6 Gb/s (upto 500MB/sR | 450MB/sW)
2nd Hard Disk
CORSAIR 750W PRO SERIES™ HX750-80 PLUS® SILVER MODULAR (£114)
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE INTEL CPU COOLER (£19)
Network Facilities
NO OFFICE SOFTWARE
Quantity
1
Price: £1,394.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/comput...ivy-bridge-pc/
Probably not much difference but I think the 680 has the edge, there are a lot of comparisons around if you google it.
http://www.techpowerup.com/162498/GT...enchmarks.html
Super Star
But the 7970 is almost £100 cheaper, and better for higher resolutions.
I'll say what I was told when I was planning my build and asking various gamer-techy friends - the first thing they pointed out to me was to get an SSD. You have that lovely mobo, RAM and GPU, but you might find the HDD will bottleneck it up a bit, so invest in a small SSD for your OS and any vital programs/games. Then you can store all your files on the HDD. That said, you HDD is quite fancy, but I would still get a small SSD in there, I promise you won't regret it!
Also, drop the trial versions of Microsoft Office and the AntiVirus, that still will just get annoying when it demands to be upgraded and just takes up space. Either get the full version, or just get something free like Open Office when you get the machine if you need those kinds of applications. Plenty of good, free AntiVirus programs out there too.
Probably won't need 16GB RAM if you're just gaming. 8 should cover it fine at this point, unless you're planning to do crazy stuff with photoshop and similar editing programs.
Morality is temporary, wisdom is permanent. ~ HST
GW2 game tag: kokabel.5728
Steam: kokabaal
Intel Core i7 Quad Core Processor i7-3820 // ASUS P9X79 // 8GB Kingston HyperX Genesis DUAL-DDR3 // 4GB Nvidia Geforce GTX 680 // 120GB Kingston HyperX 3K SSD
SSDs are just so much faster than HDD - they're basically the next step in the evolution of storage. Most people pair their Solid State Drive with a big Hard Disk Drive to get the most performance and the most storage, since right now SSDs bigger than 120GB cost an arm and a leg and several teeth. Running your operating system and vital programs from the SSD rather than from the HDD will give you a very noticeable boost in the speed at which these things load and respond.
Skip to about 40 seconds for a fairly straight forward comparison in performance between the two types of drives.
Reason: edit, did not mean to double post, there was another post in-between!
Steam: kokabaal
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Powered by
vBulletin® Version 4.2.1
© PC Specialist Ltd
