Results 1 to 5 of 5
  1. #1
    New Member Reputation: 0
    Join Date
    May 2012
    Posts
    8
    Rep
    0
    What fan and how to install
    I was thinking of buying and installing a new 200mm fan in my Coolermaster HAF 912 Plus Case i havent decided where to put it (either side/top) would it be better for it to be on the side or top to keep my GPU Cooler?
    What 200mm fans do you recommend and how would you install one into the case?
    Would the addition of a new fan remove my 1 year collect and return warranty?
    My max required wattage is 560W for my current rig from my 650W PSU is the addition of a 200mm fan okay?
    Thanks
  2. #2
    Grand Master Reputation: 5581
    Join Date
    Jan 2012
    Posts
    6,443
    Rep
    5581
    Quote Originally Posted by jrobbertss View Post
    Thanks
    Adding the fans should not affect your warranty unless you damage the components while doing it but that is pretty unlikely. Fitting the fans is pretty straight forward, I recently bought this one:
    http://www.bitfenix.com/global/en/pr...-pro-led#specs
    The manual of your case should indicate how to reach the top of your case to fit in the fans.
  3. #3
    Join Date
    May 2012
    Posts
    8
    Rep
    0
    Are instructions included with the purchase of the fan?
  4. #4
    Join Date
    Jan 2012
    Posts
    6,443
    Rep
    5581
    To be honest, never checked. I think there are pictures but it is something you don't really need instructions to. I have never fitted a fan before and found it pretty straightforward. You can always post your queries if you are unsure on how to fit them on the forum once you are ready to install them.
  5. #5
    Expert Reputation: 3128
    Join Date
    Jul 2011
    Location
    York, England, East Yorkshire
    Posts
    3,171
    Rep
    3128
    I have one of the blue Spectre pro fans, it's great
    All you need to do is screw into the right hole then attach the header to the appropriate connector
    Corsair Carbide Series 500r ~ i5-3570k @ 4.5Ghz ~ EVGA GeForce GTX 670 FTW Edition ~ MSI-Z77A-GD55 ~ 8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz ~ Cooler Master GX650W ~ Asus Xonar DGX 5.1 Surround Soundcard
    ~ Scythe Kaze Master Pro ~ Corsair H100 ~ 750GB Total Storage ~ Corsair 60GB Force Series GT SSD
    UltraNote - Intel® Core™i3 Dual Core Mobile Processor i3-3110M (2.40GHz) 3MB ~ 4GB SAMSUNG 1600MHz SODIMM DDR3 ~ Intel® HD Graphics 4000 ~ 120GB INTEL® 330 SERIES SSD
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© PC Specialist Ltd
