Results 1 to 3 of 3
  1. #1
    New Member Reputation: 0
    Join Date
    Jun 2012
    Posts
    7
    Rep
    0
    HDD LED question
    Just got an Enigma III last week and I'm not sure if it has been like this from the very start and I just never noticed it, but the HDD led flashes almost constantly, even when there are no programs running or I am for example just looking at a webpage. It can be quite distracting in the dark as the light from it is fairly bright. Is it normal for there to so much HDD activity? I would say that it flashes on average once every 2 seconds and never goes more than 4 seconds with no flashes. Thanks in advance.
  2. #2
    Enthusiast Reputation: 27
    Join Date
    May 2012
    Location
    Sunny South Cheshire
    Posts
    101
    Rep
    27
    That's normal.
    Vortex II 15.6" Glossy / Core i7-2760QM / 16Gb Samsung 1333mhz / ATI Radeon 6990M 2Gb @ 830/1050 / 240GB SanDisk Extreme SATA3 SSD / 750GB WD Scorpio Black 7200rpm / Killer 1102 WiFi
    Please don't forget to add to my reputation if you think what I just said helped you, or at least made sense!
  3. #3
    Join Date
    Jun 2012
    Posts
    7
    Rep
    0
    Thanks for the fast reply. I did assume that it was very probably the norm, but thought I might as well ask.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© PC Specialist Ltd
