Results 1 to 3 of 3
  1. #1
    Member Reputation: 0
    Join Date
    Feb 2012
    Posts
    56
    Rep
    0
    COOLIT ECO II C240 A.L.C - Any socket? not 2011
    Does anyone know why if the COOLIT ECO II C240 A.L.C says it's compatible with any CPU socket.
    I can onl opt for the rubbish intel cert water cooling if I order an 2011 socket overclocked CPU?
    Thanks for the help guys.
    Regards
    Matmoo
  2. #2
    Super Star Reputation: 1104
    Join Date
    Dec 2010
    Posts
    1,962
    Rep
    1104
    unfortunately not. Not fully covered on the details to why though.
    Not sure why but it should as its similar to the corsair h100 which is also by coolit.
    CM STORM SNIPER | Intel i7-2600k | ASUS P8P67 DELUXE | 1.5GB GTX 580 | 16GB KINGSTON HYPER-X 1600Mhz
    240GB OCZ VERTEX 3 | 2TB WD CAVIAR BLACK | x2 3TB WD CAVIAR GREEN | 600GB WD VELOCIRAPTOR HLHX
    CORSAIR HX750W PRO | COOLIT ECO A.L.C | Sound Blaster ZxR
    Razer BlackWidow Ultimate 2013 | Razer Ouroboros
    Windows 7 Pro 64 Bit
    Rep not needed...BuT if any of my posts helped...Press that Rep button for hoards of Reps stampeding your way
  3. #3
    Join Date
    Feb 2012
    Posts
    56
    Rep
    0
    Quote Originally Posted by Teaz View Post
    Okay,
    Thanks for the help.
    Any one know why?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© PC Specialist Ltd
