Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Master Moderator Reputation: 9617
    Join Date
    Sep 2010
    Posts
    5,752
    Rep
    9617
    Quote Originally Posted by Jackogeddes View Post
    considering its an 8 year old dell i bought for like £49 i'm guessing so - thanks
    Haha,yes it's a pretty safe bet.
  2. #12
    Bright Spark Reputation: 288
    Join Date
    Nov 2010
    Posts
    256
    Rep
    288
    I would strongly recommend one of these
    http://forums.nvidia.com/index.php?showtopic=160941
    http://m.youtube.com/watch?v=Wcpa-Iuol7k
    It was my choice after much research and its can be had for £130 now . Its hd and 3d ready and will serve your rig well.
  3. #13
    Master Moderator Reputation: 6114
    Join Date
    Jul 2010
    Location
    Reading, UK
    Posts
    4,328
    Rep
    6114
    Remember that it won't hurt your GPU if you use a much older, smaller resolution monitor, so if you need to save up a bit more before you get your new monitor then it won't be a problem.
    In this case it just means you won't be using your GPU to anywhere near its potential.
    If you can afford a new monitor I'd definitely get one though, the difference between a new 22-24" monitor and an old 19" will be huge.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© PC Specialist Ltd
