Results 1 to 8 of 8
  1. #1
    Super Star Moderator Reputation: 1884
    Join Date
    Feb 2012
    Location
    Dublin
    Posts
    1,228
    Rep
    1884
    Decent E-atx Case
    Hey all
    Im looking for a decent Extended-ATX case. Im not a fan of the Haf X. Anyone any other suggestions for a nice case. If possible white.
    Links/Pics appreciated.
    If I've helped at all please feel free to add Rep by clicking the little star
  2. #2
    Rising Star Reputation: 1276
    Join Date
    Apr 2012
    Location
    South West England Wiltshire
    Posts
    772
    Rep
    1276
    Give credit where credit is due hit the star give me(+rep)
    Corsair Carbide Series 400R,i5-2500k@4.8ghz,Titan Fenrir EVO,Nvidia GeForce GTX 680,
    120GB-SSD,2tb-HDD,TX650,8gb kingston HyperX,Maximus V GENE
  3. #3
    Member Reputation: 0
    Join Date
    Dec 2011
    Posts
    30
    Rep
    0
    I wish PCS did those in white, and not just the orange and black one. The white one looks awesome. Would go nice with 4 LED fans on the side.
  4. #4
    Bright Spark Reputation: 626
    Join Date
    Feb 2012
    Location
    Devon - UK
    Posts
    474
    Rep
    626
    Hi buzz how about the cooler master cosmos 2 , a little pricey but supports XL-ATX & has a lot of fan bays - very nice indeed
    http://www.coolermaster.co.uk/produc...roduct_id=6781
    Coolermaster HAF - X (200mm x 3 Blue LED + 230mm Red LED fans)
    ASUS® P8Z68-V/GEN3: PCI-E 3.0 READY, SLI, CROSSFIREX
    Intel® Core™i5-2500k Quad Core (3.30GHz)
    TITAN FENRIR EVO EXTREME
    2 x Nvidia GTX 680 - 4Gb (SLI)
    2 x 2TB SEAGATE Barracuda SATA 6Gb/s HDD, 64MB Cache (7200rpm)
    CORSAIR 1200W PRO SERIES™ GOLD AX1200-80 PLUS® GOLD MODULAR
    Windows 7 Ultimate (x64)
  5. #5
    Grand Master Moderator Reputation: 5428
    Join Date
    May 2011
    Posts
    7,269
    Rep
    5428
    CM storm trooper or the stryker edit this aint a e atx case sorry thought it was
    OR NZXT Switch 810 - Buzz, I will have the green eyed monster and remove you from steam if you buy this case,
    CM Storm Trooper Pictures
    CM Storm Trooper - Intel I7 2600 @3.4 - Asus P8Z68 V Pro - 16Gb Kingston Hyper X Genesis 1600Mhz - 2GB EVGA GTX 680 Superclocked - Corsair HX1050 - Noctua NH-D14 - 120GB Corsair Force GT SSD - 1TB WD Caviar Black - 2Tb WD Caviar Green - Asus DX - Lamptron FC 8 - NZXT HUE LED Controller - Tritton Ax Pro - 2X IIyama 24Inch - CM Storm Quickfire TK - Razer Imperator
  6. #6
    Grand Master Reputation: 2447
    Join Date
    May 2011
    Posts
    6,373
    Rep
    2447
    My case supports e-atx, and if you dont like the yellow the offer an all black version which is the same design but without the yellow
    Its an akasa venom toxic
    Please add to my rep if I have helped you
    Get into folding here
    PC Pictures
    Spec
    | Akasa Venom Toxic | Akasa Venom Voodoo | AMD FX8150 | 8GB HyperX | GTX570 | Corsair TX850 | 256GB SSD |
    | 120GB SSD | 2TB SATA III | NZXT Sentry Mix | Gigabyte M8000X | Razer Arctosa | Turtlebeach PX5 | Iiyama 24" x2|
  7. #7
    Join Date
    May 2011
    Posts
    7,269
    Rep
    5428
    Whatever ya go for buzz, it must have a window! So you can show off those 690's!
  8. #8
    Join Date
    Feb 2012
    Location
    Dublin
    Posts
    1,228
    Rep
    1884
    Hey folks
    Thanks for the suggestions. Its much appreciated. I reckon ill go with the switch 810. Seems to have everything I'm after.
    Thanks again. Have some rep for your troubles.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© PC Specialist Ltd
