Grand Master
Optimus III, low fps!
hey all,
so am trying to test the sims 3 on my optimus III, 650m,
getting about 15 fps on max settings,
getting about 20fps on medium,
checked the temps of the 650m, its sat at about 54c doing nothing, whereas the integrated gpu was at 70+
I did press the button to use the 650m, but its not getting used.
How can i set the 650m to be used all the time?
edit - just to add
changed the settings in nvidia control panel, so the sims3 uses the high performance nvidia processor,
But it doesnt work, low fps and the game goes dull.
CM Storm Trooper Pictures
CM Storm Trooper - Intel I7 2600 @3.4 - Asus P8Z68 V Pro - 16Gb Kingston Hyper X Genesis 1600Mhz - 2GB EVGA GTX 680 Superclocked - Corsair HX1050 - Noctua NH-D14 - 120GB Corsair Force GT SSD - 1TB WD Caviar Black - 2Tb WD Caviar Green - Asus DX - Lamptron FC 8 - NZXT HUE LED Controller - Tritton Ax Pro - 2X IIyama 24Inch - CM Storm Quickfire TK - Razer Imperator
Friendly neighbourhood 'bump'
Corsair Carbide Series 500r ~ i5-3570k @ 4.5Ghz ~ EVGA GeForce GTX 670 FTW Edition ~ MSI-Z77A-GD55 ~ 8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz ~ Cooler Master GX650W ~ Asus Xonar DGX 5.1 Surround Soundcard
~ Scythe Kaze Master Pro ~ Corsair H100 ~ 750GB Total Storage ~ Corsair 60GB Force Series GT SSD
UltraNote - Intel® Core™i3 Dual Core Mobile Processor i3-3110M (2.40GHz) 3MB ~ 4GB SAMSUNG 1600MHz SODIMM DDR3 ~ Intel® HD Graphics 4000 ~ 120GB INTEL® 330 SERIES SSD
Grand Master
Originally Posted by
Corfate
lol
hahah nice
I cant get the laptop to use the 650m at all, it wont do anything... -.-
Grand Master
tom_gr7
lol
hahah nice
Have you try other games?
HAF-X i7-2700k Quad Core - 2GB NVIDIA GEFORCE GTX 680 SLI - 240GB INTEL® 520 SERIES SSD - 2TB WD CAVIAR BLACK - CORSAIR 1200W PRO SERIES - COOLIT ECO II FAT BOY - NZXT Sentry 2 Fan Controller - Asus Xonar DX Sound card - 3 x ASUS VG278H 27" Monitor 3D
If I've helped you please feel free to add a Rep by clicking on the little sheriff badge in the left bottom corner
Grand Master
rubensolo
yep
the same issue, cant seem to run on the 650m at all!
go into graphics setting in the nvidia control panel and enable sim3 on the nvidia optimus settings? (Don't know the exact steps but I've heard a similar story and this solved it for him)
basically you are using intel 4000 and 650m isnt enabled at all
worth a try?
hmm maybe see if you can enable the 650 globally (temporarily) so it is always on and see if its a faulty gpu or not
tom_gr7
hey all,
edit - just to add
tom_gr7
lol
hahah nice
tom_gr7
yep
Have you tried white-listing the games, and using the GPU monitor that comes with the Nvidia control panel?
To while-list do the following:
Here we go:
1. Right click on desktop.
2. Select Nvidia Control panel.
3. Nvidia Control panel will open.
4. Select Manage 3D Settings.
5. You will see two tabs Global Settings and Program Settings.
6. Select Glabal and select High Performance NVIDIA Processor. (This effectively turns off Optimus using the NVIDIA GPU all the time).
7. Or Select Program Settings.
8. Select Add under 1.
9. Find the game you want to white list.
10. Click on Open.
11. Under 2. Select High Performance NVIDIA Processor if not already selected.
12. Select Apply.
13. Job done, time for tea, biscuts and medals.
Regards.
C.
To enable GPU monitoring do the following:
Select Nvidia Control Panel.
Select Desktop drop down menu.
Select Display GPU activity icon in notification area.
Regards.
C.
Grand Master
thanks,
I did do all of that yesterday, and it didnt work for some reason...
But I turned it on today, and it seems to have worked, well the fps is around 50-60 on max settings at 1920 -1080.
Just need to make sure its under load with gpu z.
Yeah it seems to be working fine now, although when I alt-tab out then back in again, it goes a bit dull. But I can live with that.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Powered by
vBulletin® Version 4.2.1
© PC Specialist Ltd
