hi im an online gamer do lan pci cards improve connection or something ? also whats the differance between wirelass and cordless ??? iwant a keyboard that doesnt need contant batteries
I believe "wireless" and "cordless" are just different marketing terms rather than there being any real difference technically. If you don't want to be changing batteries every 5 minutes then stick with a wired setup or consider a rechargeable set.
You only need one of the PCI/PCI Express cards for a wireless internet connection. If you do need one of these then choose the PCI card over the PCI-E if you can. PCI is older and it's best to keep the newer slots free where possible.
so it doesnt make quicker downloads or anything?
No. You would only want to connect wirelessly for convenience/out of necessity. You're likely to lose speed and gain a less reliable connection - depending on distance.
am thinking of a 2nd pc so would be essentual then ? im confused ive got a comp wich modem is conected to and am going to buy a 2nd is it betteer to get extra cable rather than wireless lan card for my gaming pc?
If the two machines are close together then just use a router and a few cat5 cables, if the machines are in different rooms and you have a wirless router, cable the machine near the router and use a wireless card in the far off one.
Wireless connections will never be as good as a cable.
I dont work for PCS anymore, fix it yourself!
