ive not played games on pc for about 5 years but now sick of console shooters, so was hoping some people on here who know will be able to help me make a pc that can run top end graphics with out being a alien ware £2000 pc! Im looking to play online shooters mainly, i used to live on counter strike and cs source, this is what i have looked at so far any suggestions on what i should change or have instead of will be appreciated thanks. this set up is £1068 cant go much higher but im stil unsure wether ive got the right things chosen.
AMD PHENOM II X4 965 (3.40GHz/8MB CACHE/AM3) - BLACK EDITION
ASUS® M4A87TD/USB3: DUAL DDR3,SATA 6.0GB/s, USB 3.0
8GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 4GB)
ATI RADEON™ HD 5850 PCI EXPRESS - DirectX® 111GB 3
Memory - 1st Hard Disk
1TB WD CAVIAR GREEN WD10EARS, SATA 3 Gb/s, 64MB
RAID (HDD 1 & 2)
NONE RAID 1 (MIRROR) (£9) RAID 0 (STRIPE) (£9)
1st DVD/BLU-RAY Drive
24x DUAL LAYER DVD WRITER ±R/±RW/RAM Memory Card Reader
INTERNAL 52 IN 1 CARD READER (READS XD, MS, CF, SD, etc)NONE
4) system refinements
Power Supply & Case Cooling
1010W Quiet 80 PLUS Quad Rail PSU + 120mm Case Fan (£109) Processor Cooling
STANDARD AMD CPU COOLER
Network Facilities
GAMING NETWORK CARDS--------------Bigfoot Killer 2100 PCI-E Gigabit LAN Card - Max Performance Online Gaming (£69)
6 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD----------- Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) (£5)
RAID (HDD 1 & 2)
Network Facilities
