Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: help!
  1. #11
    Grand Master Reputation: 2447
    Join Date
    May 2011
    Posts
    6,373
    Rep
    2447
    my files are now appearing on my desktop YAY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! thank you so much (gives mishra big kiss and hug and lots and lots of rep)
    Please add to my rep if I have helped you
    Get into folding here
    PC Pictures
    Spec
    | Akasa Venom Toxic | Akasa Venom Voodoo | AMD FX8150 | 8GB HyperX | GTX570 | Corsair TX850 | 256GB SSD |
    | 120GB SSD | 2TB SATA III | NZXT Sentry Mix | Gigabyte M8000X | Razer Arctosa | Turtlebeach PX5 | Iiyama 24" x2|
  2. #12
    Bright Spark Reputation: 462
    Join Date
    Feb 2011
    Location
    Leeds, UK
    Posts
    303
    Rep
    462
    glad you get it working finally. Now then, for the future, read first then do... don't do same mistake twice :P
    AMD Phenom II X4 955 @3.9Ghz | Noctua NH-D14 | Gigabyte GA-870A-UD3 | 4GB DDR3 HyperX | Asus GTX 560Ti @920Mhz | CoolerMaster Haf 912 Plus | SanDisk Extreme SSD, Momentus XT | Noctua fans all over the place
    <--- click little star if I helped you, help me to reach my goal of more rep than posts!
  3. #13
    Join Date
    May 2011
    Posts
    6,373
    Rep
    2447
    will do next time, but it sohuld have really had a warning for someting that deleted my files instantly after pressing it
    for some reason, firefox is now in black and white :/ everything else is in colour.. will try a reboot of it, and who said only windows puts programs unresponsive, ive had it about 10 times in the past few minutes
    PC Pictures
    Spec
  4. #14
    New Member Reputation: 1
    Join Date
    Feb 2011
    Location
    Bracknell
    Posts
    14
    Rep
    1
    If you have nowhere to back up your best data, then keep in mind that various on line facilities such as Ubuntu One, Spideroak, Dropbox (and there are more I am sure) usually offer a free account with maybe 5GB free storage each. So although a bit inconvenient, and maybe slow to upload it (?) at least ther are a few places to temp store some of your stuff. Good luck.
  5. #15
    Join Date
    May 2011
    Posts
    6,373
    Rep
    2447
    should be getting my computer soon with my 750GB HDD, so should be able to keep 2 copies of the majority of my files, most certainly the important ones, i completely forgot that i luckily put some of the most important photos onto my memory stick
    PC Pictures
    Spec
  6. #16
    Join Date
    May 2011
    Posts
    6,373
    Rep
    2447
    god dammit even though im running it under root, i have to somehow unlock the folders once back on the harddisk before i can do anything
    PC Pictures
    Spec
  7. #17
    Join Date
    May 2011
    Posts
    6,373
    Rep
    2447
    good news, my external HDD has just appeared with all the files on it and is working fine, very strange, lucky i didnt begin to create a new partition
    PC Pictures
    Spec
  8. #18
    Join Date
    Feb 2011
    Location
    Leeds, UK
    Posts
    303
    Rep
    462
    Get them backed up on a DVD/CD meanwhile, USB stick, online, just anything .. unless you are happy to delete them straight away... cause sooner or later it will happen.
    It is beyond my understanding how anyone can have "important" files only on one drive, no backup at all.... even Kazakhstan have some sort of backup in place, you should too
  9. #19
    Join Date
    May 2011
    Posts
    6,373
    Rep
    2447
    its not really convenient to put them on another HDD (my main photos are on both drives now) but i will be when i get my computer, i dont see the point in getting a second external, seeing as it just sits there, it cant really break can it? i dont have it plugged in 99% of the time, ill take the risk until i get my new computer
    PC Pictures
    Spec
  10. #20
    New Member Reputation: 0
    Join Date
    Feb 2012
    Posts
    1
    Rep
    0
    You can recover deleted data from partition using relevant data recovery tool. I have used hard drive recovery tool to recover lost data from inaccessible partition. This software can also recover accidentally deleted files from different types of hard drives like SATA, SCSI and IDE. Lost data from accidentally deleted or missing partition can also be recovered easily. File recovery from formatted partition or hard drive is also possible by this software. This software supports different versions of Windows Operating System like Windows XP, Windows Vista and Windows 7. Download free demo version of this software to view recovered files. If you find lost files in recovered data list then use full version of this software to save recovered files.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© PC Specialist Ltd
