redorblue89
Hi bought my desktop from PCS a while ago, I've had all these components for at least a year, no problems with the GPU till now. This has happened three times in one day now then after a few restarts or a bit of time it sometimes works.
I'm using msi afterburner with a custom fan profile so I know how the fan should work. I started playing splinter cell blacklist the other day and the I could hear the fan spin up and then slow down over and over ever second or so. I checked afterburner and it showed the GPU at 80c and the fan speed had been trying to set at like 60% but always dropped back to 30% a second later.
I tried to manually apply a set fan speed of 70% and it speeds up then just drops and stays at 30% but the fan speed bar is still set to 70. Default auto profile has the same effects.
What could be the problem? Anyone experienced this before? I've tried with 320.49 drivers and 326.something beta drivers. Same results.
specs:
- i7 2600K
- GTX 670 FTW 2gb (320.49 drivers, been using for months no problems)
- 8gb ram
- win 7 pro 64-bit
- 750w corsair tx psu
specs:
- i7 2600K
- 8gb ram
- win 7 pro 64-bit
