Hi everyone,
To give some context, I've been a Windows user in transition to Linux for quite some time now. I'd already noticed some slightly strange behaviour when experimenting with live USBs, for example, that unless I did a live boot directly after a Windows restart, the wifi wouldn't work in the Linux live session. Sometimes after live boots, I'd have to re-enable wireless in the Windows mobility centre.
I finally took the plunge by installing Linux over Windows on my 15.6" Ultranote, and now the wireless won't work at all. I've tried numerous fixes, none of which have yielded anything.
These include:
running "sudo rfkill unblock all" - this does not work, as it it believe the wifi is disabled by a hardware switch, though to my knowledge the Ultranote has no such switch.
Resetting the BIOS by draining the CMOS battery. All this did was make it think it was midnight on a Tuesday.
Installing firmware for the N-2230. I've not noticed any difference.
Right now I'm using an ethernet cable for the internet and it's good and quick, but I really need this machine to be portable.
Sidenote: I tried entering setup by pressing F2 during the boot, but it doesn't seem to be working which is worrying! It's like the BIOS has vanished.
These include:
