How to open PCS Hush! Silent Mini-ITX case?
dreixel
Hi all,
I've bought a mini PC some 3 years ago. I moved home now, and the mini PC doesn't boot since then, because the CPU fan won't start. I was gonna open the case to have a look (it could just be accumulated dust or so), but it turns out I can't figure out how to open the case. Below some pictures.
Any hints? I've already removed all the screws I could find, and I can easily remove the lower part of the case; what I really need is to remove the top part, though.
Thanks in advance!
steaky360
I really cannot find any info on this anywhere, my advice would be to give PCS a call - they should be able to tell you over the phone how to open up the case to get at the innards :)
