Just received PC today - No Monitor Signal
Lorkem
Hi everyone, My new PC was delivered today, Powered it up and was greeted with the No Signal on my Monitor.
Cables are all connected properly, tried re-seating the RAM, Video card. Also tried a different cable and monitor. POST beep happens and all fans running and lights are on but just no display.
Specs:
Intel® Core™i7 Quad Core Processor i7-4790k (4.0GHz) 8MB Cache
CORSAIR OBSIDIAN SERIES™ 750D FULL TOWER CASE
ASUS® MAXIMUS VII RANGER: PCI-e 3.0, SATA 3.0, USB3.0
16GB KINGSTON HYPER-X FURY DUAL-DDR3 1600MHz (2 x 8GB)
4GB NVIDIA GEFORCE GTX 980 - 1 DVI, 1 mHDMI, 3 mDP - 3D Vision Ready
1st Hard Disk
250GB Samsung 850 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
2nd Hard Disk
2TB WD CAVIAR BLACK WD2003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
1st DVD/BLU-RAY Drive
CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
CoolerMaster Hyper 212 EVO (120mm) Fan CPU Cooler
Genuine Windows 8.1 64 Bit - inc DVD & Licence
keynes
You could try disconnecting the gpu and connecting directly to the motherboard. If it works then there is something wrong with the gpu.
Rakk
The Awesome
Just as a quick question, you are plugging your monitor into the graphics card and not the motherboard? - I realise this may sound like a stupid question.
Lorkem
Not a silly question at all as it's easily done! But it is connected to the Graphics Card :) Will try your suggestion Keynes.
Lorkem
Glad you got it sorted :)
Blame all the potholes for it coming loose :)
Thanks :) Haha, yeah it probably was all those flaming potholes as well!
I was being a bit of a wuss not pushing it into the motherboard as much as I should've done, was scared of damaging anything and then I heard that clicking into place sound that was music to my ears.
