Results 1 to 6 of 6
  1. #1
    Member Reputation: 2
    Join Date
    Apr 2011
    Posts
    53
    Rep
    2
    16GB 1333MHz or 8GB 1600MHz: which is better?
    Which is better? My instinct says the extra 267MHz is better than the extra 8GB, but the Samsung 16GB config is much more expensive than the other one.
  2. #2
    Super Star Reputation: 346
    Join Date
    Oct 2010
    Location
    West Sussex
    Posts
    1,162
    Rep
    346
    Whats it going to be used for? If overclocking then 1600Mhz.
    But for uses such as video editing most definitely 16gb.
    For gaming, neither, 4gb 1333Mhz will do fine 8 at most.
    CM690 MKII Advanced
    AMD PHENOM II X4 970
    4GB SAMSUNG 1333Mhz RAM
    1.25GB NVIDIA GTX470
    1TB WD CAVIAR GREEN WD10EARS 3G 64MB Cache
    CORSAIR TX650
    IIYAMA E2271HDS 22" LED WIDESCREEN, FULL HD 1920x1080
    Windows 7 x64 Premium
    Creative Gigaworks T20 2.0
  3. #3
    Expert Administrator Reputation: 820
    Join Date
    Jul 2010
    Location
    Huddersfield
    Posts
    2,147
    Rep
    820
    As JSG10 has said, it all depends on what you will use the PC for. If you get back to us with that info then we'll be able to make a recommendation for you.
    These forums are not an official channel for support, if you have a problem with your machine please ensure you notify us through our official channels. These are through our website mail system or by calling Tech support direct on 0844 499 4000.
    Alternatively for general enquiries email [email protected], to see current waiting times at our call centre click here.
    Don't forget the "rep system" - if you found my post helpful then click the REP star at the bottom of the post!
  4. #4
    Join Date
    Apr 2011
    Posts
    53
    Rep
    2
    Ok here's a spec:
    Chassis & Display
    Vortex II-17: 17.3" Full HD LED Backlit 16:9 Widescreen (1920x1080) Super Clear Glossy
    Intel® Core™i7 Quad Core Mobile Processor i7-2820QM (2.30GHz) 8MB Cache
    8GB KINGSTON HYPER-X GENESIS 1600MHz SODIMM DDR3 (2 x 4GB)
    1.5GB nVIDIA® GeForce® GTX 460M - DirectX® 11 (17.3" Vortex II)
    Memory - Hard Disk
    250GB INTEL® 510 SERIES SSD, SATA 6 Gb/s (upto 500MB/sR | 315MB/sW)
    DVD/BLU-RAY Drive
    SONY BC-5500H 4x BLURAY ROM/DVD WRITER & CYBERLINK SOFTWARE (£84)
    So I like to play around with photos in photoshop, maybe render a youtube video or two, and why not play some games. Do I stick with this ram, go for the 16gb 1333, or stick with this and buy an extra 8gb 1600mhz elsewhere? p.s. why isnt 16gb 1600mhz an option?
  5. #5
    Join Date
    Jul 2010
    Location
    Huddersfield
    Posts
    2,147
    Rep
    820
    I think don't think the Motherboard can support 16GB running @ 1600MHz, there will be a reason why it's not available to order.
    Personally, I think 16GB is over the top for 90% of users. I'd save a bit of money and get 8GB 1333MHz. You also then have the option to add another 8GB 1333MHz in the future, if/when the laptop begins to struggle.
  6. #6
    Join Date
    Apr 2011
    Posts
    53
    Rep
    2
    Hi I just noticed Origin PCs offer 16gb at 1600Mhz on this one http://www.originpc.com/eon17-s-gami...p-features.asp
    I think it's the same machine. So I guess it can run that much ram?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.2
Copyright © 2015 vBulletin Solutions, Inc. All rights reserved.
© PC Specialist Ltd
