london_paul
Hello
I've been searching around trying to configure a PC to use primarily for photography (raw processing in lightroom and capture one, not photoshop). I don't play games and so didn't think a graphics card would add anything at the moment (and assume one could be added later without too much bother if that changes) and tried to spec the computer to have sufficient processing power, a decent amount of RAM (with an easy upgrade option) and a lot hard drive space (which seems to be the recommendation I keep finding for photography related builds).
I tried to find a micro-atx option to reduce the physical size but haven't been able to find that (smaller is better in my flat!). Is that possible/advisable? I also looked at a similar mini-atx option for about £100 more but with two RAM slots which would mean an upgrade would require replacing both sticks of RAM, is that a problem?. I wasn't sure how small PCs performed relative to larger machines and whether it would be better to go a bit larger to allow for more future proofing - ideally I would like to keep the PC running for more than 5 years.
Otherwise, is this PC generally ok/likely to suit my needs?
My budget is under £1000 and the less I spend on the PC gives me more for a better monitor.
Thanks for any help!
Paul
PCS GENESIS G1B CASE + SD CARD READER
Intel® Core™ i5 Six Core Processor i5-8400 (2.8GHz) 9MB Cache
ASUS® PRIME Z370-P: ATX, LGA1151, USB 3.1, SATA 6GBs
16GB Corsair VENGEANCE DDR4 2666MHz (2 x 8GB)
INTEGRATED GRAPHICS ACCELERATOR (GPU)
1st Hard Disk
500GB WD Blue™ 3D NAND 2.5" SSD, (upto 560MB/sR | 530MB/sW)
2nd Hard Disk
DVD/BLU-RAY Drive
INTEL STANDARD CPU COOLER
Genuine Windows 10 Home 64 Bit - inc. Single Licence [KK3-00002]
Quantity
1
Price £845.00 including VAT and delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z370-pc/WGJpeegJhF/
Paul
1st Hard Disk
2nd Hard Disk
DVD/BLU-RAY Drive
Quantity
1
