pellyadolfo
Hi, maybe someone else has a similar case.
I purchased a Cosmos VI 17'' September last year. Here are the specs. I installed Ubuntu, currently Ubuntu 16.04.
For almost one year I really enjoyed the laptop, best one I had ever. I forgot what is waiting for a program to compile or delays in processing. Everything on the fly.
However, last Sunday, something new happened. I began to hear a vibration on the laptop in the left side of the keyboard. Initially I thought it was a car on the street, but I turned off the laptop and the noise was gone. :-( I live in a very wet city in South Ireland and now the weather is quite hot, but it has been hot already for 2 months. I have monitored temperature last 2 days and it does not go further from 50 degrees, which I think is ok, but this left side of the keyboard is a bit warm. I do not think it was before. The right side of the laptop is perfectly cold.
My guess is that there is some fan on the left side which is either dirty and maybe needs just a maintenance cleaning after 10 months of active usage, or the fan is malfunctioning, and I am afraid it can damage other components if I do not take some action. So I have 3 problems now: the vibration, the noise, and the threat to damage other components.
I would like to know if you have any similar experiences. Questions that come to my mind:
* how did you solve it?
* I am waiting delivery of a hard drive to do a full backup and then I will update to Ubuntu 17 just to see if there is any progress as well. I remember that I updated Ubuntu about 3 weeks ago.
* Do you have any schema of the laptop to confirm that there is a fan in Cosmos VI on the left side?
* what are the options now: should I send it back to PCS (still under the 1 year guarantee) or to the local retailer for a maintenance cleaning?
* If I send back to PCS, should I use the original box? How long would they delay in returning it to me?
* do you have any Ubuntu tool that I can use to learn more about the issue?
I appreciate you share your experiences.
Regards,
Adolfo
Regards,
Adolfo
