Hi! Received our new mini pc yesterday and have just found the time to set it up, but there's no power lead! I wanted to check this isn't normal before I contact PCS on Monday. I assume it should come with a power lead, right? Thanks!
I thought I could use the lead from our big pc but it's definitely a smaller one. Will give them a call tomorrow, didn't realise they were open.
Actually just noticed it's the same size as the lead that feeds into our laptop lead transformer box. Can I just use that?
Checked my order history and the laptop lead is 1 x UK Power Lead & 40W AC Adaptor
The mini pc should have come with 1 x 1 Metre UK Power Cable (Kettle Lead)
And below is a pic of the power supply "in" bit from the mini pc, and the laptop power supply (which says 13A)
I won't do any damage will I?
Thank you so much! All set up now, really pleased with it
