Hi. Looking for a PC that I can connect my Xbox to and a web cam to so that they can both be streamed to YouTube as well as recorded for potential editing.
What would be a good set up for about £650 or am I setting my budget too low?!
My understanding of this, is that it could be done via X-split, but you would need some kind of 'capture card' like the Elgato, to be able to record footage. I know most Twitch/YouTube streamers will have 2 monitors, one where the the game is viewed on it, and the second monitor to control the webcam and streaming app, like Xsplit or OBS. Theres a number of guides on how to do it via YouTube.
As for using a computer for streaming etc, I've seen builds combine a 1060 6gb and Ryzen 2600x for streaming 1080p using encoding etc.
You'd need a video capture card if you don't already have one.
You don't need much of a GPU as for streaming you'll generally have the CPU do the encoding - and for that matter if you're running the game off the Xbox and feeding it into the capture card, the capture card will handle the encoding afaik. The CPU would matter a lot for video editing.
The GPU could play a much bigger role in video editing. But with your budget you won't get much of a GPU.
One option would be:
PCS 6003B BLACK CASE Processor (CPU)
AMD Ryzen 5 2600 Six Core CPU (3.4GHz-3.9GHz/19MB CACHE/AM4)
---Tom Clancy's The Division 2 FREE w/ select AMD Ryzen CPUs! Motherboard
Gigabyte B450 AORUS ELITE: DDR4, USB 3.1 - RGB Ready Memory (RAM)
8GB Corsair VENGEANCE DDR4 2666MHz (2 x 4GB) Graphics Card
2GB NVIDIA GEFORCE GT 1030 - DVI, HDMI 1[SUP]st[/SUP] Storage Drive
240GB ADATA SU650 2.5" SSD, SATA 6 Gb (520MB/R, 450MB/W) DVD/BLU-RAY Drive
NOT REQUIRED Power Supply
CORSAIR 350W VS SERIES™ VS-350 POWER SUPPLY Power Cable
1 x 1 Metre UK Power Cable (Kettle Lead) Processor Cooling
STANDARD AMD CPU COOLER Thermal Paste
STANDARD THERMAL PASTE FOR SUFFICIENT COOLING Sound Card
ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD) Wireless/Wired Networking
10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED) USB/Thunderbolt Options
MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS Operating System
Genuine Windows 10 Home 64 Bit - inc. Single Licence Operating System Language
United Kingdom - English Language Windows Recovery Media
Windows 10 Multi-Language Recovery Image - Unlimited Downloads from Online Account Office Software
FREE 30 Day Trial of Microsoft® Office® 365 (Operating System Required) Anti-Virus
BullGuard™ Internet Security - Free 90 Day License inc. Gamer Mode Browser
Microsoft® Edge (Windows 10 Only) Game Streaming
Elgato Game Capture HD60 PRO - PCIe Card Warranty
3 Year Standard Warranty (1 Month Collect & Return, 1 Year Parts, 3 Year Labour) Delivery
STANDARD INSURED DELIVERY TO UK MAINLAND (MON-FRI) Build Time
Standard Build - Approximately 6 to 8 working days Quantity
1
Though I'd very strongly recommend a better case and a better PSU or else you're cutting yourself off at the knees with upgrade options.
The R5 2600 is a capable video editing / streaming CPU. The B450 mobo rather than the A320 as you actually are using PCIe add in cards here. The 240gb SSD is cheaper than a 1TB HDD and you can add more storage in the future.
AMD Ryzen is cheaper, has much higher multithreaded performance (generally better for video encoding and streaming) and the motherboard supports more upgrade options, in short.
