Anyone have any idea how to control the led strips in my case?
I got the black friday deal, the case fans are fine, i can control these using the case it'self.
However slightly confused at what software i need in order to manage the rgb strips inside the case?
Any ideas?
thanks
Assuming PCS connected them to the motherboard RGB header you'd need gigabyte's.. app centre.. and fusion..?
https://www.gigabyte.com/Motherboard/Z390-UD-rev-10
I can't get on their website right now, the page refuses to load, but you can check that link out now or later - go to the support / drivers tab - and find the relevant software
