I have a custom 18.4 laptop from you which is about 2 years old.
First problem is with the fan, which is really loud if the laptop is not in minimal use ( like watching hd film, multi tasking... ). I tried to clean it with an air duster ( from inside ofc ) but it doesnt work. Problem must be with the bearings.
Second problem is that the monitor turns off and doesnt come back. Everything else is working, but I can`t see anything. It happened a couple days ago, and I turned the laptop off, left it for 10-20mins and turned back on and it was fine. Now it happened again, wanted to do the same process, but it doesnt come back, so I cant use it now. I think there is a problem with the graphic card. I haven`t used it really, it`s now just next to my pc and doing the downloads there and skype and sort of things. It wasn`t warm at all.
Is there any product number on it to make it easier for you to indetify this custom laptop?
