3dBenchmark query/problem
Dark79
Can anyone recommend or help with the current Benchmark im using.
Ive got a copy of 3dbenchmark vantage v102 and there are 4 tests, 2 gpu and 2 cpu, the gpu tests run fine but the cpu tests just give me a blank no signal screen for a min or so flashing back to load next for a second then no signal, finally it comes up with a score of 16,800 gpu score but cpu score is blank.
Any ideas, im a newby to all this benchmarking lark, the only thing i changed in the settings is the resolution to 1920x1080 - this is what ive got it set to for windows too, Im running on a 42 inch tv is this the problem or are there any settings i need to change that I do not know about. ?
Dark79
Hi Gorman,
My specs ....................
ANTEC 900 BLACK GAMING CASE (£79)
Intel® Core™i7 Quad Core Processor i7-950 (3.06GHz) 4.8GTs/8MB Cache
ASUS® P6X58D-E: DDR3, USB 3.0, SATA 6.0GB/s, 3-Way SLI
6GB CORSAIR XMS3 TRI-DDR3 1600MHz (3 X 2GB)
1GB NVIDIA GEFORCE GTX460 GDDR5 PCI EXPRESS - DirectX® 11
2nd Graphics Card
3rd Graphics Card
NONE
Memory - 1st Hard Disk
40GB Intel® X25-V 2.5" SSD (34nm / upto 170MB/sR | 35MB/sW)
2nd Hard Disk
640GB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
RAID
NONE
1st DVD/BLU-RAY Drive
2nd DVD/BLU-RAY Drive
NONE
INTERNAL 52 IN 1 CARD READER (READS XD, MS, CF, SD, etc)
Power Supply & Case Cooling
•Sound Blaster® X-Fi™ Titanium PCI Express (£66)
Gorman
Ok, make sure you have the latest drivers for the 460's installed. And run the test again using the default settings. Let us know what happens.
Dark79
Ok the drivers are the latest for the x2 460's have ran default settings (only changing the resolution to 1920 x1080p as would not display anything without this chane) and still not signal on cpu tests, just wanted to add all my games run perfectly.
