Welcome to our forums
The 48.84WH batteries tested as follows on the 15.6" Optimus II:
Test 1: Playing a movie (stored on hard disk, not DVD) with the Optimus settings on amber (GPU turned on): 2 hours 25 minutes
Test 2: Playing a movie (stored on hard disk, not DVD) with the Optimus settings on green (GPU turned off): 3 hours 30 minutes
The 62.16WH battery has a 27% larger capacity than the 48.84WH version and so you can expect 27% longer on the above tests, so in test 1: 3 hours and 4 minutes and in test 2: 4 hours and 26 minutes.
Does the 62WH Battery petrude from the casing? Is it extra long or extra wide for the extra capacity? - I Want to buy on extended battery, but it would be inappropriate if it does not fit onto stands securely (used on stage...)
