5k dream PC.
Soulqt
Hello everyone.
I've finally managed to get into a point where I can get my dream PC and I need your assistance.
Basically my budget is about 5k with about 500-700 to float in.
I'm looking for a computer to stream, play triple A upcoming PC games that might have Unreal 5 etc. do some basic video editing and have the ability to do some VR content too.
Inside my 5k~ budget I wanna include 2 screens from 24 to 27 inches tops, cam, mic and a chair since I'm rebuilding everything from scratch.
The PC I'm currently planning to buy looks like this, but I would love any short of input to make this as good as it can get.
FRACTAL DEFINE 7 XL BLACK QUIET TOWER CASE
64GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 16GB)
24GB NVIDIA GEFORCE RTX 3090 Ti - HDMI, DP
CORSAIR 1200W HX SERIES™ MODULAR 80 PLUS® PLATINUM, ULTRA QUIET
Corsair iCUE H115i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Monitor
AOC 24G2U 24" 144Hz Gaming Monitor - DP
2nd Monitor
Gaming Chair
GT Omega PRO Racing Office Chair - Black Next White Leather
Webcam
Logitech® HD Webcam C930e - 1080p recording, supports H.264
Microphone
Elgato Wave:3 Condenser Microphone
Honestly mate wait until later in the year with that budget. The new GPU and CPU are due to come Autumn and by all early whispers it's going to be a decent performance jump
I'd say rethink your monitor choices though for this level of build you really want a 4K monitor, I'd personally go for a Samsung G9 which is essentially two 1440p monitors in one panel so need for multiple monitors either
You could just buy a cheap £100 1080p 60Hz one to monitor stream stuff, don't need anything fancy for that
Cracking system but that CPU & GPU selection is wild to pair with such a setup.
It's like trying to power a Fiat 500 with an ICBM powerplant.
Soulqt
I see. I think I'll follow Steves advice and wait on it for a bit. If I get too antsy I'll have another look at it, but I waited for so long, I can wait a bit more i believe.
Thank you for the answer, I really haven't built a pc for more than 10 years, i have close to no idea what's going on.
You're absolutely in the right place and it's good that you've came to the forum before pressing the buy button as you would be surprised at the amount of people who don't, and end up down similar rabbit holes.
If you get some free time, have a look through the following:
It should have you in a much better position to both offer us the information we need, and understand more reasoning with our feedback :)
Soulqt
After reading the post and trying to connect the dots I've made something that looks like this. But I'm unsure on if I should be looking on an intel or AMD CPU so my core might still be faulty.
I understood that I do not need a 3090 for sure.
Threw in some extra storage cause I'm a hoarder and I wanna store stuff on the HDD and then have an SSD for windows/apps and another SSD for games.
Also if the setup is around 4k I realised that I can get a new computer later on and give this to a family member and by the time I need an upgrade I'll have the money to do so, so I might actually get whatever we end up with by the end of July or August.
Thanks for everyone's time and input btw, i really appreciate it.
Intel® Core™ i9 18 Core Processor i9-10980XE (3.0GHz) 24.75MB Cache
GIGABYTE X299 UD4 Pro: USB 3.1, SATA 6 GB/s - ARGB Ready!
12GB NVIDIA GEFORCE RTX 3080 - HDMI, DP, LHR
1TB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
PCS FrostFlow 150 Series High Performance CPU Cooler
ASUS PCE-AX3000 Wi-Fi 6 (802.11ax) 2400Mbps/5GHz, 600Mbps/2.4GHz
MIN. 2 x USB 3.0 & 6 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Microsoft® Edge
Monitor
Samsung LS27A700NWUXXU 27" 4K FreeSync LED Monitor
Monitor
ASUS TUF GAMING VG249Q1A 24"
Gaming Chair
Webcam
Microphone
Price: £4,303.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-x299-pc/tWPQBxhZY5/
Microsoft® Edge
Monitor
Monitor
Gaming Chair
Webcam
Microphone
Oh mate this is considerably worse in almost every way
With your budget and and uses in mind, I would go with this and get a proper 4k 144Hz monitor to suit it. Then use the left over cash to get the rest of the items
FRACTAL MESHIFY 2 LIGHT TEMPERED GLASS
Intel® Core™ i7 12-Core Processor i7-12700K (3.6GHz) 25MB Cache
ASUS® TUF GAMING Z690-PLUS WIFI D4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
2TB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7300MB/R, 6900MB/W)
Microsoft® Edge
Price: £2,867.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/UebJpT4Wxj/
Soulqt
Microsoft® Edge
Haha, thank you. I guess I got more confused than anything. That setup actually looks like what I was trying to achieve. I'm gonna look for a 4k 144hz monitor to finish it up and I think I'm gonna order it next month. I'll probably ask again just in case anything new comes up, but I'm saving your setup as a point of reference. Thank you a ton!
