7770 graphics card display issues
Hi
I have bought a amd 7770 graphics for my desktop, the card works and the fan spins, but when I change the display to VGA and the monitor says no signal ? Is it to do with the power supply or bios ?
Thanks
keynes
Hi
Thanks
Difficult to tell without your full spec. I assume the HDMI/DVI works fine?
baron75mk2
Banned
may just be that the gpu is throwing out a resolution thats two low for the monitor when engaged in vga , uninstall the driver with hdmi connection , turn off , connect vga & boot again , see what happens - it happened to me way back in the dark vga days
