Hi All
Set up is 4770k at 4.4ghz 1.25vcore, cooled with H80i configured to extract air out the back. I have 2 frontal intake chassis fans also.
My problem is when I am doing stress test or folding @ home my CPU hovers around 85c, often reaching up to 92c even when fans are all maxed out. It also reaches high 80's using crysis 3. Idle temps are fine, around 28/29.
I do not think this is safe for 24hr use, but I also do not want to go under 4.4Ghz, and to get 4.4ghz I need 1.25v!. I have some mx-4 thermal paste which just arrived as I was going to refub the laptop.
Do you think it is worth reapplying thermal paste? Is there anything else other than de-lidding that I can do to get these temps under control?
If my CPU did mess up due to overheating during my 3year gold, will that still be covered?
Other info: 1x GTX 770, good airflow in Fractal R4 case.
Thanks!
Thanks!
