Hi
It's been a while since i've been in the world of desktop pc's, i built my own about 6 years ago but things seem to have change a bit, especially power supplies etc.
I've ordered a pc from PCS with CM Stormtrooper case, an Asus P9X79 Pro motherboard (and overclocked cpu) and have a few questions.
I was considering putting a few of these inside the case for a bit of additional cooling.
First question is would you put them on the bottom sucking in(as there is a dust cover on the bottom of the case) or on the side which would seem to be more normal (as well as the colour being more visible)
If i put them on the side is there any dust cover people can recommend to cover the left side of the case to stop dust being pulled into the case
Or, would you just leave it all as it is?
Cheers, your help is much appreciated
