About to order, want some expert forum advice! :)
MacTellsar
Hi folks,
I used to be into gaming PCs oooooh, about 25 years ago back when Half Life and Quake 3 were the cream of the crop. It's been a while.
I've just sold my PS5 and would like to join the gaming PC masses so I can play with my mates who made the move over too. Now, whilst I use to be able to build my own PCs back in my teenage years I now know almost nothing about what I need.
Ideally, I'd like a machine that can run pretty much any latest release at nearly highest settings. I'm mainly a FPS player and I already own an LG Ultra Gear GP950 4k monitor which I used on the PS5 and would ideally not like to have to upgrade unless I have to.
Here's the PC I just specced on the site. Any advice would be hugely appreciated. I'd love not to have to upgrade anything for a year or so, although I accept I don't know how quickly tech improves in the space any more so that might be wishful thinking.
Thanks in advance for any pointers/tips! Oh and one game I definitely want to play is Concord. Here are the recommended specs they posted recently as a benchmark for what I'd love to be able to run: https://x.com/PlayConcord/status/1810392214888952262
SPECS:
Case CORSAIR 4000D AIRFLOW TEMPERED GLASS GAMING CASE
Promotional Item Get a discount code for 20% off select peripherals at Corsair.com
Processor (CPU) Intel® CoreTM i9 16-Core Processor i9-12900K (Up to 5.2GHz) 30MB
Cache
Motherboard ASUS® PRIME B760-PLUS D4 (LGA1700, DDR4, PCIe 5.0)
Memory (RAM) 16GB Corsair VENGEANCE RGB PRO DDR4 3600MHz (2 x 8GB)
Graphics Card 16GB NVIDIA GEFORCE RTX 4070 Ti SUPER - HDMI, DP, LHR
Graphics Card Support Bracket NONE (BRACKET INCLUDED AS STANDARD ON 4070 Ti / RX 7700 XT AND
ABOVE)
1st M.2 SSD Drive 512GB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 3500MB/sR,
1625MB/sW)
1st Storage Drive 2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB
CACHE
Power Supply CORSAIR 850W RMx SERIESTM MODULAR 80 PLUS® GOLD, ULTRA QUIET
Power Cable 1 x 1.5 Metre UK Power Cable (Kettle Lead, 1.0mm Core)
Processor Cooling PCS FrostFlow 360 Series ARGB High Performance Liquid Cooler
Sound Card Creative Sound Blaster® Audigy Rx
Network Card ONBOARD LAN PORT
Wireless Network Card NOT REQUIRED
USB/Thunderbolt Options MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT
PORTS
Keyboard & Mouse ASUS ROG SCOPE II 96 WIRELESS Keyboard
Headsets SteelSeries ARCTIS NOVA 7 Wireless Gaming Headset
Ekans2011
Hi folks,
SPECS:
Cache
ABOVE)
1625MB/sW)
CACHE
PORTS
It would be helpful if you could read the following and provide the missing information.
MacTellsar
Sorry
Sorry I thought I'd covered all of these in my post.
My monitor is: LG Ultra Gear GP950 4k monitor
The use is FPS gaming
My budget is around £2500 max.
Ekans2011
Here you are; slightly over budget (£34), but it is worthwhile in my opinion.
If you can't go above budget, you should consider a Radeon GPU (7900XTX), which excels at rasterization but struggles with NVIDIA technologies (DLSS, RT, FG).
LIAN LI LANCOOL 215 GAMING CASE - Budget case with decent airflow; not the first choice, but necessary to keep prices down.
AMD Ryzen 7 7800X3D Eight Core CPU (4.2GHz-5.0GHz/104MB w/3D V-CACHE/AM5) - Best gaming CPU on the market.
ASUS® TUF GAMING B650-PLUS WIFI (AM5, DDR5, PCIe 4.0, Wi-Fi 6) - Solid MB, Prime boards are really a poor choice.
32GB Corsair VENGEANCE DDR5 6000MHz (2 x 16GB) - Frequency sweetspot for AM5.
16GB NVIDIA GEFORCE RTX 4080 SUPER - HDMI, DP, LHR - High-end 4K GPU to handle your LG resolution.
512GB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 4700MB/sW) - Fast OS boot drive.
2TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 3325MB/sW) - Main drive for games/programs.
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET - ATX 3.1, transient spikes protection, plenty for future GPU upgrades (unavoidable).
CORSAIR ICUE LINK H115i RGB HIGH PERFORMANCE CPU COOLER - Premium 280mm AIO, better efficiency, less noisy, less cables and better overall quality than PCS ones.
ONBOARD 2.5Gbe LAN PORT
Firefox™ - Non-Chromium based browser
Price: £2,534.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/A6ktYh7JTq/
MacTellsar
This is awesome, thanks so much!
I could probably go a little over budget. Case wise, I don't want anything flashy, the more muted the better, but which would be a better option than the budget one you suggested, from a cooling point of view?
Thanks again, I really appreciate the guidance.
Just to add to this - great spec there from Ekans. When it comes to the "flashy" RGB and stuff, this can all be controlled by either software or unplugging the RGB cables from the motherboard.
5 years ago I bought a PC with ALL RGB everywhere, apparently having more RGB made your PC run faster back then HAHA!
I've since grown up and just switched all the RGB off except for my CPU Cooler which I have set to Temp Controls, green when chilled, yellow, orange and red for when it is time to pause the game and go and make a brew.
Seeing the RGB in the cases and put so many people off, but this can all be turned off.
Ekans2011
How much over budget? :)
