Hi - the spec of the PC I’m planning to buy is below. Does it look ok? At the moment my daughter mainly plays Roblox and Fortnite, but is keen to start playing Call of Duty. She’s also interested in editing video a bit.
Is the Spec ok? do the components match ok? Will it be easy to upgrade components at a later time if I need to?
any help would be great, as I’m a bit out of my depth here 😁. Thanks.
Case | PCS SPECTRUM RGB MID TOWER CASE (WHITE/PINK) |
Processor (CPU) | Intel® Core™ i5 Six Core Processor i5-11400F (2.6GHz) 12MB Cache |
Motherboard | ASUS® PRIME Z590-P (LGA1200, USB 3.2, PCIe 4.0) - ARGB Ready |
Memory (RAM) | 16GB PCS PRO DDR4 2666MHz (2 x 8GB) |
Graphics Card | 8GB NVIDIA GEFORCE RTX 3050 - HDMI, DP, LHR |
Graphics Card Support Bracket | PCS GRAPHICS CARD SUPPORT BRACKET |
1st Storage Drive | 512GB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 450MB/W) |
1st M.2 SSD Drive | 500GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3200MB/W) |
DVD/BLU-RAY Drive | NOT REQUIRED |
Power Supply | CORSAIR 450W CV SERIES™ CV-450 POWER SUPPLY |
Power Cable | 1 x 1.5 Metre UK Power Cable (Kettle Lead) |
Processor Cooling | PCS FrostFlow 100 V3 Series High Performance CPU Cooler |
Thermal Paste | ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND |
Sound Card | ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD) |
Network Card | 10/100/1000 GIGABIT LAN PORT |
Wireless Network Card | ASUS PCE-AX3000 Wi-Fi 6 (802.11ax) 2400Mbps/5GHz, 600Mbps/2.4GHz |
USB/Thunderbolt Options | 2 PORT (2 x TYPE A) USB 3.0 PCI-E CARD + STANDARD USB PORTS |
