Hi all,
I don't really have experience of custom builds and am looking for your advice. I'd like to get a desktop machine that performs well while gaming, and also has a large amount of RAM and processing power for some scientific computing. I've made a first pass attempt, but I didn't really know what I was selecting for many of the options. In particular, I was hoping for 64Gb of RAM but couldn't see that as an option. If anyone could cast an eye over and let me know if this is a suitable setup or if you would make any substitutions, I would really appreciate your expertise. This is pushing my budget a bit at £3300, so any unnecessary expenditure can go.
Case: PCS SPECTRUM II ARGB MID TOWER CASE (PWM)
Processor (CPU): Intel® Core™ i9 10 Core Processor i9-10900X (3.7GHz) 19.25MB Cache
Motherboard: GIGABYTE X299 UD4 Pro: USB 3.1, SATA 6 GB/s - ARGB Ready!
Memory (RAM): 64GB Corsair VENGEANCE RGB PRO DDR4 3600MHz (4 x 16GB)
Graphics Card: 24GB NVIDIA GEFORCE RTX 4090 - HDMI, DP
1st M.2 SSD Drive: 1TB PCS PCIe M.2 SSD (3500 MB/R, 3200 MB/W)
Power Supply: CORSAIR 1000W RMx SERIES™ - MODULAR 80 PLUS GOLD, ULTRA QUIET
Power Cable: 1 x 1.5 Metre UK Power Cable (Kettle Lead, 1.0mm Core)
Processor Cooling: CORSAIR ICUE LINK H115i RGB HIGH PERFORMANCE CPU COOLER
Thermal Paste: STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
LED Lighting: 50cm ARGB LED Strip
Sound Card: ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Network Card: 10/100/1000 GIGABIT LAN PORT
Wireless Network Card: Tenda AX3000 Wi-Fi 6 (802.11ax) 2400Mbps/5GHz, 600Mbps/2.4GHz
USB/Thunderbolt Options: 2 PORT (2 x TYPE A) USB 3.1 PCI-E CARD + STANDARD USB PORTS
Additionally, I plan to dual boot with Windows and Linux Mint. I assume the process of this is exactly the same as with every other machine I've done this with in the past?
Thank you for your help!
Hefin
Hefin
