Advice on 14inch laptop
Derngek
Hi guys,
I was wondering if I can get some advice on which small form 14 inch laptop I should get and the recommended specs for it.
I will be using it mainly for microsoft office, web browsing, youtube, occasional zoom calls
I won't need it for gaming.
My budget would be up to £800
Thanks.
Hi guys,
Thanks.
I'd suggest the Premium Lafite Pro with modular RAM (not the cheaper soldered version).
This is quite well specced for the budget, lovely chassis and has quite powerful graphics which is really good for the budget. Added benefit of Thunderbolt 4.
Chassis & Display
Lafité Pro Series: 14" Matte Full HD 60 Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i5 Quad Core Processor i5-1135G7 (2.4GHz, 4.2GHz Turbo)
8GB Corsair 3200MHz SODIMM DDR4 (1 x 8GB)
Integrated Intel® Iris® Xe Graphics
512GB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
AC Adaptor
1 x 65W AC Adaptor
Battery
Lafité Pro Series Integrated 49WH Lithium Ion Battery
1 x THUNDERBOLT 4 + 1 x USB 3.2 (TYPE C) + 2 x USB 3.2
Keyboard Language
LAFITÉ PRO SERIES SINGLE COLOUR BACKLIT UK KEYBOARD
Keyboard & Mouse
Webcam
INTEGRATED 1MP HD WEBCAM
Chassis
Clevo NV41MZ (i5-1135G7, FHD 60Hz N7, Blank KB)
Price: £767.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/lafite-pro-II-14/8ujAsXE3fJ/
Derngek
Thanks for that.
Noted on the ram part.
Curiously for my user case scenario is it worth me increasing the ram to 16gb and upping cpu to i7 for the extra £100 or would it be overkill?
Thanks for that.
CPU always worth it, get the best you can. If it's only £100 then the extra RAM would certainly benefit if you have lots of tabs open for web browsing as that can take a lot of resources. Zoom also is quite memory hungry.
It's definitely worth doing both if you can push the budget.
