Advice on cleaning PC - can I remove front panel?
jacmer
Hi folks, hopefully this post is in the right place on the forums - it’s my first time posting here! Also I am far from knowledgable on PCs so sorry if I don’t explain this clearly or with the correct terminology.
A few years ago I purchased my first PC from PC Specialist and have usually been cleaning out the case every so often using a can of compressed air and some cotton buds. I’ve noticed that dust builds up a lot on the vented section on the front of the case, and often even if I do my best cleaning the fans on the inside of the vent with cotton buds, there will still be a significant amount of dust shooting through the vented section every time I spray my compressed air through. Is this normal? And if not is there a way for me to detach the front panel of my pc to give it a more extensive clean?
Again I apologise if I’m using the wrong or confusing terminology - please do let me know if I am! I am about to give it a clean and have attached a picture of the interior and exterior of the front of my pc, if more are needed then I can upload some! Thanks for your time and help.
Is that the Fractal Focus G? If so, grab the front panel at the bottom and pull outwards, that should unclip it from it’s housing.
It’s a bit of an investment but I’d thoroughly recommend picking up one of these. Much more cost effective than cans of compressed air in the long run and a lot more powerful.
So treat yourself to the blower, use a little bit of electricians tape to stop the fans spinning freely, take the whole tower outside (make sure it’s not a rainy day) and go to town on it. You should be able to get it looking pristine again.
jacmer
It is the Fractal Focus G! I managed to get the front off and give it a good clean - I’m going to grab that blower too once I get paid for sure as well, so thanks for your help!
P.S. The owls are not what they seem.
sck451
You will definitely want to clean that radiator on the back panel as well. That amount of dust build up could significantly affect cooling performance.
