I'm looking to get into 3d printing and 3d design, I'm completely new to pc's so everything is a learning curve.
I'd like a pc that is suitable for fusions 360 which I understand is only single core so clock speed is important, I've looked at intel 14700k,14600k, amd 7700x and amd 7900x all have high clock speed and are 8 core plus. I get these are probly overkill for cad software as my designs will be very simple, but I'd like to think I can progress onto blender and other software which is more cpu heavy so I'd like a machine which is either upgradeable or decent spec that will last me years without needing to upgrade.
This pc will not really be used to game as I have a xbox but the option to game would be handy.
Fusion 360 don't really use gpu so an expensive one is pointless I was looking at a navida 1650, possibly a 3060 bought elsewhere and fitting myself as pc specialist Is a little expensive on that card.
Heres what I picked out so far
Case will be be quiet! Pure Base 500DX Black MIDI Tower Case bought elsewhere as pc specialist don't seem to do be quiet, also I wanted the deepcool ak620 as air cooler but it is currently out of stock.
Any advise on if this of overkill for my needs would be greatly appreciated
Send In Your Own Case
AMD Ryzen 9 7900X 12 Core CPU (4.7GHz-5.6GHz/76MB CACHE/AM5)
ASUS® PRIME B650-PLUS (AM5, DDR5, PCIe 4.0)
32GB Corsair VENGEANCE DDR5 4800MHz (2 x 16GB)
Graphics Card Support Bracket
1TB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 6500MB/sW)
CORSAIR 750W CX SERIES™ CX-750 POWER SUPPLY
CORSAIR H100x RGB ELITE HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
2 PORT (2 x TYPE A) USB 3.0 PCI-E CARD + STANDARD USB PORTS
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
Keyboard & Mouse
ASUS TUF K1 Gaming Keyboard & M3 Gen II Mouse Bundle
Price: £1,265.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/G7zjNQ7BS7/
Microsoft® Edge
Keyboard & Mouse
