Advise on mount wall arm for LG 34 GN850 | PCSPECIALIST
Lemon_Haze
Hi lads, sorry if this is not correct thread, but im wondering what stand would you recommend for plasterwall for my lg 34 ultrawide please?
I was thinking about this one
Many thanks
scarpa1
The above one looks fine and has the right vesa size but I would go with something that has more movement to it so you can easily pull it out and get to the connections etc.
You can pick some decent ones up on Amazon, I got one for my 55 inch TV and its really good.
The fittings that came weren't suitable though as I have plasterboard dot and dabbed onto thermo blocks so I had to buy some specialist fixings.
I got some Rigifix Anchor fixings and they are probably the best fixings I have ever used.
Are your walls plasterboard and wood studs or like mind just dot and dabbed to the blocks? If they are wood studs then the fixings that come with the brackets would be fine, but any drywall or like mine you will maybe need some better fixings though the monitor won't weigh anywhere near my TV weight but I guess with a monitor you are perhaps moving it around more.
Lemon_Haze
Thanks mate, mine is just with wood studs, I also found this one on amazon would think it would be better? Thanks for the recommendation again!
scarpa1
Yes that one looks good, full motion ones are really good, easier to get to connections and just gives you far more movement and adjust options than the other ones.
