AI Suite and Windows 11
JonT
New PC arrived today and I am extremely happy. Finally I can use Lightroom, Paintshop etc without going insane :)
Has anyone installed AI Suite on Windows 11. There is only a version for Windows 10 on the ASUS download page for my motherboard.
I ask because the case is noisier than I had expected. There isn't a lot of load going through the system, but the fans sound to be working pretty hard. I wanted to use AI Suite to see what was going on, and fine tune if necessary.
Spec below for completeness.
Thanks all.
CaseCOOLERMASTER SILENCIO S600 QUIET MID TOWER CASE
Processor (CPU)AMD Ryzen 7 5800X Eight Core CPU (3.8GHz-4.7GHz/36MB CACHE/AM4)
MotherboardASUS® TUF GAMING B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
Memory (RAM)64GB Corsair VENGEANCE DDR4 3200MHz (4 x 16GB)
Graphics Card8GB ASUS TURBO GEFORCE RTX 3070 - HDMI, DP, LHR
1st Storage Drive4TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 128MB CACHE
2nd Storage Drive4TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 128MB CACHE
1st M.2 SSD Drive1TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2500MB/sW)
RAIDRAID 1 (MIRRORED VOLUME - 2 x same size & model HDD / SSD)
DVD/BLU-RAY DriveNOT REQUIRED
External Hard Drive2TB Seagate One Touch External HDD, USB 3.0, Black
Power SupplyCORSAIR 750W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingCoolerMaster Hyper 212 (120mm) Fan CPU Cooler Black Edition
Extra Case Fans2x 120mm Black Case Fan (configured to extract from rear/roof)
Wireless Network CardASUS PCE-AC88 AC3100 2100Mbps/5GHz, 1000Mbps/2.4GHz
scarpa1
I have it on mine and its working fine. I only use it for one fan and my water pump (liquid series) as my other 6 fans are controlled by L Connect but I haven't had any problems with ai suite since updating to windows 11.
sck451
Are you sure it's the fans making the noise? I'd expect those hard drives to be quite loud, to be honest, as they're designed for servers, rather than desktop computers.
JonT
You could be right. I went in through BIOS and fans are super slow. Hard drive choice was slightly odd because this PC is also serving as primary storgae for my photo library (also backed up to NAS and OneDrive)....not that I'm paranoid about losing the library or anything ;)
EDIT - Nope, it was the fans after all. I downloaded AI Suite and ran the fan tuner. Now the whole rig is almost completely silent. Bliss.
