AIO Mounting - Roof or Front?
EchoDarkly
Hi all,
I've bought a build in the last few days (see total config below for details), and I've been reading up on the Corsair H150i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler.
I've seen a lot of thoughts and videos regarding where it should be mounted (top or front panel). The case I have is the Corsair iCUE 5000X RGB mid tower case.
I was wondering if:
  1. Anyone knew what the size of the cooler will be (280mm, 360mm, 420mm)?
  2. What the standard placement of the cooler is for this case?
  3. People's thoughts on placement?
Is there any benefit to it being top or front? Or is it minimal and it should just be aesthetic preference? Do I even have a choice with this particular case? 😂
Thanks for any info 👍
500GB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7000MB/R, 3000MB/W)
Promotional Item
Get Guardians of the Galaxy with select GeForce RTX™ 30 Series GPUs
Welcome Book
Logo Branding
PCSpecialist Logo
sck451
The H150i is a 360mm radiator (i.e. three 120mm fans). On the 5000X it can be mounted on the front, on the top, or on the side panel in front of the motherboard.
The normal place to mount it would be on top, which I would imagine will be where PCS puts it. It won't make a huge difference one way or another in terms of temperatures and performance.
Generally the best place for it is on the roof
Usually the 5000X comes with the H150i mounted on the roof from PCS as well
I will say though the H150i was specifically for the 5000X and the window on the rear panel was designed for that radiator to fit. I personally think it looks fantastic here and leaves the roof free for more fans but it's definitely suboptimal in terms of airflow.
Most likely mounted on the roof and that would be the best place for it. Aesthetically I like it on the rear panel window
EchoDarkly
Hi all,
Thanks for the replies (tried to rush back here to edit my post when I saw the promo video for the cooler on Corsair's website and in big letters it says "H150i - 360mm 🤦‍♂️😂)
If there's no real difference to performance, then it's fine if it's on the roof (think I prefer the tubes heading up rather than across).
Thanks everyone 👍
sck451
Hi all,
Thanks everyone 👍
There's a real difference, but it's not a big one, and either option has its downsides. On the front means better CPU cooling and worse GPU cooling. On the top means better GPU cooling and worse CPU cooling. Either way it's not a huge difference, and a top mount is cleaner and simpler and it's easy to do in the 5000X.
