Android Wear WIFI Issue: PLEASE READ IF YOU HAVE AN ANDROID WEAR DEVICE | PCSPECIALIST
The latest versions (updates released on the 10th and 14th of November) the Android Wear Companion app on android break the WIFI functionality of you device. Your WIFI will work fine until it gets turned off at wich point it won't come back on (it will turn its self of straight away). If you have this issue uninstall the app until the is a fix available (I will post back at said time) at which point the app will connect with your watch as if nothing had happen.
**Temporary Fix**
Use the search function in settings to find the Scanning menu. This is a part of the location section of settings, then turn off Wi-Fi Scanning and Bluetooth Scanning.
