NilSatis
You need to go into Power Management and see if there are any features that are putting the pc into a power saving state at any time. I dont think this will be your problem but it is worth a check; go to control panel, then system, then power management, and then set up the pc to a high performance plan. May not look like it does much but can be a problem if it is using power saving features on the pci-express parts of the pc, or in other areas.
Have you scoured what else is running on the pc at the same time as when these games are being used? It would be worth running some software that comes with Advanced System Care called "Game Booster" which can provide some performance increases as it turns off background processes when gaming. Would be worth it just to see whether anything is really causing performance issues in the background. If you dont have Advanced System care, it is an excellent little tool. Game booster can come with it, or you can download seperately. One of the main benefits is it will show you things that are running in the background that maybe more of a problem than you think, and you can select which ones to turn off and on etc.
I suggested looking at Overdrive in ccc as if there is anything amiss with Power Management on the card itself through corrupt drivers or something similar, then turning up the clock speeds in ccc can get the cards out of the idle power management state that they can get stuck into. You can turn up the sliders on both core and memory clock with no ill affects in ccc, it basically gives the cards a mild overclock; but only in the realms of an increase that the driver will allow (basically bugger all) but you can also adjust how much power in voltage the card can draw when it is trying to work hard, by altering power control settings in ccc. It may be worth bumping this up and seeing whether anything changes on these games too. You wont ruin anything as long as you stay in the areas the sliders allow in ccc. The cards can take far more than these small adjustments so you will be fine. If it seems to have done something positive then alter them back again and see whether the problem comes back. You can do this before and after running a game.
I would also check some other things before reinstalling Win7 although it is probably going to be your best bet soon if nothing else works.
1. Check device manager and check that there are no warnings there. If there are then this may be a problem.
2. Remove all drivers again; open the case up, remove the gpu by hand and reseat it. Then reboot. Let windows install its vga drivers if necessary and then reinstall the latest drivers that worked well on your card. See if there is any improvement now, and while the card is out remember to have a good clean of the fan/heatsink if possible.
3. Have you tried other games? If it only happens on one or two games then check out whether there are any problems with direct x, or the game installations themselves. type dxdiag in the run box of windows to run some direct x diagnotics and see if everything is detected ok there. Im pretty sure this wont be the problem, but again worth a try.
4. This one is definitely worth a try; after uninstalling all drivers using a driver cleaning utility (if you like using them) and reinstalling 12.8; the latest drivers, you may want to turn off a function called ulps which basically is what controls the lower power state of the card. Try to download this small program and turn the ulps off. It may also be worth a read so you know how to turn it off in future. There has been some suggestion on ATI forums, as mentioned before; that the later drivers have messed this setting up for the older cards, especially ones that use crossfire. So you can use this program to remove the low power state; until the problem is resolved. Or just to try it!
ULPS software
Let us know whether this did anything.
ULPS software
