ASUS RTX 3090 - 3 Blinking Lights
The_Fat_Hog
It doesn’t seem to be a problem, it plays games, it does everything it did before the blinking lights, and it just suddenly popped up with me doing nothing different. BUT blinking lights on the GPU seems like trouble.
I’ve googled it and most seem to say it’s a power problem. I find that hard to believe. To me, the only thing I have noticed that is the problem is the blinking lights, the computer behaves no different regardless of what I throw at it.
I’ve updated software, hardware, motherboard, cpu and gpu, everything and anything that has the option to update I’ve updated it.
Kindly help with any suggestions.
Thank you
James.
COMPUTER SPEC
CORSAIR OBSIDIAN SERIES™ 500D SE CASE
Processor (CPU)AMD Ryzen 9 5900X 12 Core CPU (3.7GHz-4.8GHz/70MB CACHE/AM4)
Change to: AMD Ryzen 7 5800X Eight Core CPU (3.8GHz-4.7GHz/36MB CACHE/AM4)
MotherboardASUS® ROG STRIX X570-F GAMING (USB 3.2 Gen 2, PCIe 4.0) - ARGB Ready!
Memory (RAM)32GB Corsair VENGEANCE DDR4 3600MHz (2 x 16GB)
Graphics Card24GB NVIDIA GEFORCE RTX 3090 - HDMI, DP
Change to: 24GB ASUS ROG STRIX GEFORCE RTX 3090 - HDMI, DP
1st Storage DriveNOT REQUIRED
Change to: 1TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
1st M.2 SSD Drive500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W)
Change to: 1TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
2nd M.2 SSD Drive2TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 1000W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Change to: CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingCorsair H115i RGB PLATINUM Hydro Series High Performance CPU Cooler
Extra Case FansNONE
Windows Recovery MediaWindows 10 Multi-Language Recovery Image - Supplied on USB Drive
BrowserGoogle Chrome™
Change to: Microsoft® Edge (Windows 10 Only)
The_Fat_Hog
Solved. I turned the computer off by the power button. Then I switched it off via the power switch on the psu. And then turned the psu switch on. Then turned the computer on by the power button. And the lights disappeared. Logged into windows and the blinking lights remain off.
I still don’t understand WHY that solved it. But temporary fix maybe? No idea.
Apologies for messing people around.
Assuming that you’ve got separate GPU PSU cables running to the GPU and they’re not off splitters then it’s a false reading, it’s quite common on the strix models.
Might be worth checking if there’s an updated vbios for the card but run this past PCS before updating as may affect your warranty if they’re not aware:
The_Fat_Hog
Thank you I have emailed them as well to see what they think when they reply I’ll ask that question
makan
Same story here ASUS ROG STRIX GEFORCE RTX 3090 and those red lights... Just noticed it 3 days ago.
They are blinking regardless of whether power is on or off...
