Audio flickering
Vaio
Hi guys, I have a pair of logitech speakers connected to the PC which work fine, however when I turn on my BT headphones and connect to the PC the sound on the bottom right hand corner will keep flickering between the monitor sound (the monitor doesn't have speakers) and the PC's default sound. It will keep flickering (with no sound out of any devices) for around 10-20 seconds before connecting to the headphones. Again, when I turn the headphones off, it will do the same and finally find the speakers.
I've tried to disable all "sound" options i.e. the monitor through sound settings and it still appears to pop up.
I'm using windows 10 and this has basically been the case since I got the PC in June. TIA
