Not sure if this is allowed/correct but I have logged this with PCS Tech support as well, but wanted to see if anyone else had any suggections.
This is the 2nd time this has happened from the point it was delieved 5 days ago, the USB disconnection and reconnection sound just keeps playing.
At first I though it was one of my devices, but even with them all unplugged it still happens, the 1st time I found in Device manager a WinUSB device I could disable without impacting anything fixed the issue, however even after shutdowns and restarts the USB device sound keeps playing.
Using a program called USBDeview shows the device as the following -
Device Name - 0008.0000.0001.005.003.000.000.000.000
Product ID - 18f3
Vendor ID - 0b05
Driver filename - WinUSB.SYS
friendly Name - AURA LED Controller
Drive version - 10.0.19041.1
This looks to be a common issue as it shows up a lot from a google search but the most common fix is to use a powered USB hub, but as I dont have any USB devices apart from my mouse and keyboard im at a lost as to which USB device is losing power ?
Hardware is ASUS® CROSSHAIR VIII HERO WIFI, 2x 50cm ARGB LED Strip running off Aura sync, 3 corsair RBG fans running off a commder PRO and two different kinds of RBG hubs.
Any suggestions.
Product ID - 18f3
Vendor ID - 0b05
Any suggestions.
