Hi I am looking to buy the custom Xenon laptop in the next month or two with the following spec:
The rest seems to be pretty standard to the original spec, this comes out at £451 for the standard battery or £490 for the upgraded one. I will want to use the laptop without charge daily for up to 5 hours and I want to know what kind of battery life I can expect from each battery so I can decide whether it is worth it is needed/worth it to get the upgrade. I will want to use it with a reasonably high brightness (70%+). I will not be using any overly intensive programs, mostly web browsing and word processing.
Thanks
- i3-2330M
- 4GB Samsung DDR3 RAM
- 80GB Intel 320 series SSD
- No operating system
Thanks
