Benchmark Results Leaderboard | Page 5 | PCSPECIALIST
Buzz
Master
Nice results, The Sli really boosts those results up huh. 680's :)
Possibly even a higher result with a higher overclock.
4018 MHz up to 4.8 or 5 id be interested in seeing.
keynes
I'd like to try that but I do not have any knowledge with respect to overclocking and do not want to void my warranty if I modify the bios settings.
tom_gr7
Life Serving
i'm downloading 3dmark 11 now, wanna see how dual 580s compare to dual 680's :)
edit - ran it now, ran one test with sli disabled then a second with it enabled.
3gb 580 sli disable, P6539 3DMarks clicky
3gb 580 sli enabled, P11107 3DMarks clicky
my 2600 is at stock speeds by the way,
Rakk
"4096 MB Kingston 9 @ 667 MHz" from the 3d mark link. Should your ram not be clocked higher?
The RAM is DDR and DDR = double data rate, or it means that it can do work at twice its speed, so memory that works at 1333 actually has a base speed of 667 or something like that.
KR33PY
Pretty sure it should pick up the actual speed though, I would definitely check the bios to be sure.
KR33PY
I have no idea, did not notice that before and I am not sure what the actual speed should be.
Check your order status I'm pretty confident it should be running a lot higher Ruben depending on what ram you purchased. Find out what speed the ram was you purchased then adjust the frequency in the bios. (Also if it should be a higher frequency which I'm 99.9% positive, make sure you ask first if by changing will it effect your warranty or ask them to take you through changing it on your bios)
You should also see a higher benchmark score as well.
Gibbs
Just updated the leaderboards. Some serious scores coming in now with the 6 series Nvidia's. Who's gonna be first to post an SLI 690 score?? :D
