HI
I am considering ordering a high end gaming PC from yourselves. I am into flight simulation in VR specifically DCS World. It is very demanding on graphics and in particular the CPU. Unfortunately like a lot of sims it doesn't use all the cores primarily two so CPU speed is important. Also 32 gigs of the fastest RAM 3200? plus a fast SSD and of course a great power supply for steady overclocking.
I already have the graphics card to be used on my current system, (which is based on a I7 5930K at 4.5 ghz), this is the Gygabyte Aorus 2080ti xtreme waterforce. ( This has a closed loop 240mm rad and fans. length of tubes about 350mm) I will put this in the new system when I get it.
So the question is which would be the most suitable case you have, the system layout and ventilation logic ( rad location and pushing or pulling etc) for the new system on the basis I will need good cooling on both the CPU (240mm rad) and GPU cooler rad. I will obviously want to over clock so cooling will be essential. Also which would be the best closed loop cooler for the I9900k for this purpose. I will probably be going for the hero motherboard.
I didn't want to go for the full liquid solution as currently have the closed loop GPU already as above.
Thanks for your help on this. Apart from the query any comments on the system generally based on my needs set out above would be very much appreciated.
Thanks
Glyn
Thanks
Glyn
