Best possible build?
_Tom_
I'm looking to buy (yet another) gaming pc with the scope to do some video/photo editing.
I don't have a maximum budget and if it made sense, would pay whatever needed for the best spec.
I also don't have a monitor in mind as I'm unsure whether to go 2k or 4k. I do prefer FPS over image quality and am aware that games like RDR2 (which I love playing) would struggle to maintain 60+FPS at 4K throughout.
Any and all advice is welcome!
My potential spec is as follows:
THERMALTAKE CORE X71 TEMPERED GLASS EDITION GAMING CASE
Intel® Core™ i9 12 Core Processor i9-10920X (3.5GHz) 19.25MB Cache
ASUS® PRIME X299-A II: ATX, USB 3.2, SATA 6 GB/s, ARGB Ready
12GB NVIDIA GEFORCE RTX 3080 Ti - HDMI, DP
10TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 256MB CACHE
Corsair H150i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Extra Case Fans
2x 120mm Thermaltake TOUGHFAN 12 Case Fans
ASUS PCE-AX58BT Wi-Fi 6 (802.11ax) 2400Mbps/5GHz, 600Mbps/2.4GHz + BT 5.0
MIN. 2 x USB 3.0 & 6 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
TIMED DELIVERY TO UK MAINLAND - MON-FRI (BEFORE 10.30AM)
Promotional Item
Get Resident Evil Village with select Samsung SSDs
Welcome Book
Logo Branding
PCSpecialist Logo
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-x299-pc/PwyWMNX3M8/
MrWilson
I would definitely recommend AMD over Intel at the moment. The HEDT CPUs are poor for gaming and don't fare much better against the latest gen Ryzen CPUs.
The 5900x is the have it all chip, fantastic for both gaming and productivity.
Not sure if you'll need 64GB of RAM, unless you're doing some hardcore editing 32GB should suffice, but left it in.
Having a 10TB HDD is not what we would recommend, you want to be considering cloud storage or a NAS when you're dealing with those kind of numbers. Given you a super fast 980 pro for OS and programs, a 2tb Intel drive for your games, and a 2TB HDD for general storage.
Dropped the wireless card to the AX200, the Asus doesn't offer anything for the extra cost.
With a few graphics tweaks and a powerhouse like the 3080ti you should be getting way more than 60fps at 4k. There are a few 4k 144hz monitors on the horizon with HDMI 2.1 included, but I'm not too well versed on them. If you wanted to stick at 1440p I would recommend making space for the Samsung G9, a Superwide 240hz 1440p display. Arguably the pinnacle of gaming displays.
64GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 16GB)
Price: £3,479.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/HkwZag2JMd/
_Tom_
Thanks for the feedback and advice. @MrWilson , your configuration looks awesome! Will definitely be going with the majority of that set up. As I'm not in a rush to buy, are there any major updates or new tech coming out in the next month or two that would be worth waiting for?
Nothing lined up for a while now.
sck451
The only thing that is upcoming that might be worth thinking about is the new Samsung G7 monitor, which will be 4K 144Hz and is likely to be very good indeed. @MrWilson's build will work just fine for that as well.
Currently expected price between £2000 and 2600 though, so it's markedly more expensive, but does include the tech to justify it, it's groundbreaking screen technology.
sck451
That's the new G9, I think? I've not seen any expected prices for the new G7.
_Tom_
Interesting stuff on the monitors, cheers guys. Do you have any suggestions on any 2k monitors? I've been looking at the current Samsung G7 32" but the excessive curve puts me off.
1440p is not gonna make use of that build at all, it's far too powerful.
Understood. Monitors are a bit daunting to me so will keep researching. Im struggling to find a recommended 4k monitor that isn't 27" which again, seems a bit of a waste.
Agreed, it's generally recommended to be 32" as a minimum for 4k.
_Tom_
I posted few days ago about a possible new gaming build with the room to also do some video/photo editing and got some great advice. I have now done some more research and have put two builds together (the second build is almost identical to the one I was recommended in my first post) and was wondering if the price difference (£800) between the 2 builds I have is worth it? or should I stick to the cheaper build as I wouldn't see much difference between the two.
On a slightly different note, I was wondering if someone could also let me know the difference between the ROG Strix 3080ti and the normal 3080ti besides the price? Is it worth that price jump and would you recommend swapping out the 3090 or the original 3080ti, for it.
Thanks.
32GB Corsair VENGEANCE DDR4 3600MHz (4 x 8GB)
24GB NVIDIA GEFORCE RTX 3090 - HDMI, DP
NOT REQUIRED
Standard Build - Approximately 14 to 17 working days
Welcome Book
Price: £4,591.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/7N!SzD9Qr!/
Price: £3,746.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/qYh2djkbDB/
_Tom_
I posted a few months ago and got some good advice. Im very close to being in a position to place an order (finishing moving house), take a look at the below spec and let me know your thoughts.
Will be used to mainly game and do some video/photograph editing.
I don't currently have a monitor in mind so please do recommend. I do like the idea of an ultra wide but maybe not as extreme as the Odyssey G9.
Any questions just ask!
Cheers.
BE QUIET! BASE 601 TOWER GAMING CASE
12GB NVIDIA GEFORCE RTX 3080 Ti - HDMI, DP, LHR
4TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
Extra Case Fans
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/Gm!WCfgxpe/
Top tier build. Warrants a high end 144hz 4k monitor or a Super Ultrawide (G9)
CORSAIR OBSIDIAN SERIES™ 500D SE CASE
2TB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7300MB/R, 6900MB/W)
CORSAIR iCUE H100i ELITE LCD Display RGB CPU Cooler
Price: £3,745.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/r4r9bfEZwb/
