Bluetooth / Wireless Redragon K530 Issues | PCSPECIALIST
dtang_ie
Hi All
Just tyring to connect a new keyboard I ordered (the Redragon K530). I am having issues with bluetooth.
I am just wondering if there are two bluetooth adapters in my PC (one from Intel adapter and one from Motherboard) and if so, how do I disable one of them?
Also, has anyone owned the Redragon K530? I can't get it to connect via bluetooth and I might just return it.
Hi All
Can you post your full specs from the order page?
dtang_ie
CaseCORSAIR iCUE 5000X RGB MID TOWER GAMING CASE
Processor (CPU)AMD Ryzen 9 5900X 12 Core CPU (3.7GHz-4.8GHz/70MB CACHE/AM4)
MotherboardASUS® ROG STRIX X570-F GAMING (USB 3.2 Gen 2, PCIe 4.0) - ARGB Ready!
Memory (RAM)32GB Corsair VENGEANCE RGB PRO DDR4 3600MHz (2 x 16GB)
Graphics Card12GB NVIDIA GEFORCE RTX 3080 Ti - HDMI, DP
1st M.2 SSD Drive1TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
2nd M.2 SSD Drive2TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2700MB/sW)
Power SupplyCORSAIR 1000W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingCorsair H150i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
LED Lighting2x 50cm ARGB LED Strip
Extra Case Fans3x Corsair LL120 RGB LED Fan + Controller Kit
Warranty3 Year Gold Warranty (2 Year Collect & Return, 2 Year Parts, 3 Year Labour)
Does the keyboard come with its own dongle
Maybe try this
How to connect reDRagon k530 draconic 60% compact RGB wireless?
Q: Unable to connect K530 to device (BT4.0 and above) in BT1 mode. A: Make sure the switch of BT1 is on with red flashing light, long press FN2 + ESC till the backlit of the keyboard twinkle one time quickly. Then you will be able to find "Dracomic-1" in your Bluetooth device list, click it and to pair.
dtang_ie
Maybe try this
nah it doesnt have a dongle - ive googled and read all the reddit solution but nothing worked. i will just stick to the reputable brands.
dtang_ie
Never cheap out on components, there's a reason the branded ones cost more
I know but I already have a wired mechanical keyboard that I use to game. This wireless one is more for living room gaming when I take my desktop to my TV. Therefore, felt like not spending too much.
Ah, makes sense then (y)
If you want a good cheap wireless option for media style usage, logitech do some incredible value ones with onboard trackpad like on a laptop, and they're not expensive (£24 from amazon):
That one in particular is a bit has a bit of a godly status, it's remarkably good for the price, quite frankly it's worth at least double the cost.
dtang_ie
Haha thanks - I meant to sit in my living room and game from my TV. I don't think the keyboard will be enough for FPS, RPG etc.
