Bluetooth?
Andy in Wales
Hi,ive just received my pc build a couple of weeks ago.Ive just noticed that I don't seem to have bluetooth capability? I can't see any option for this when I had the pc built, anything I can do?
D
DeletedUser
Guest
Yeah...your spec does not have Bluetooth. Only the high end motherboards have built-in Bluetooth. Beyond that you would've needed a different Wi-Fi card (the Intel AX200) to get Bluetooth with it.
You will need to buy a Bluetooth USB dongle....something like this:
ASUS Bluetooth Dongle
D
Deleted member 17413
Guest
Could he order a AX200 off PCS as an upgrade and have it sent to him? Should be very simple to switch over.
D
DeletedUser
Guest
Thanks for your help guys.Its not clear on the spec configuration unless you're up on pc specs.lol
Turns out not even any of the Motherboards have Bluetooth so it really is just the AX200....it does say BT 5.0 if you click the Wi-Fi dropdown box but not everybody associates that with Bluetooth but think it's related to British Telecom
