Build for software development on linux
Advice appreciated for a build to be used for software development on ubuntu/popOS.
PCS P209 ARGB MID TOWER CASE
GIGABYTE GA-A320M-S2H: Micro-ATX, AM4, USB 3.1, 6GB/s
32GB Corsair VENGEANCE DDR4 2666MHz (2 x 16GB)
1GB NVIDIA GEFORCE GT 730 - DVI, HDMI, VGA
CORSAIR 450W CV SERIES™ CV-450 POWER SUPPLY
STANDARD AMD CPU COOLER
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Price: £631.00 including VAT and Delivery
Also not sure how many hdmi ports will this build have ... I need at least 2 as I have a dual monitor setup at home. Please advise.
sck451
The GT 730 is horrible: slow and ancient. It is easily outclassed by the integrated GPUs on modern chips. So I'd recommend something based around the Ryzen 5600G. (The other alternative would be one of various Intel chips, but the performance or the cost would be inferior.) You also get to use AMD display drivers, rather than Nvidia, which is great when you're on Linux.
I think you used the "office" configurator. You can get better value with the "gaming" configurator (even if you're not gaming).
PCS P209 ARGB MID TOWER CASE I'd never recommend this, but this is such a low-power system it's probably OK. Will be noisy though and I'd prefer the Lian Li 215
AMD Ryzen 5 5600G Six Core CPU with Radeon™ Graphics (3.9GHz-4.4GHz/19MB CACHE/AM4) Awesome chip for your purposes
ASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready! Perfectly good motherboard
16GB Corsair VENGEANCE DDR4 3200MHz (2 x 8GB) Less RAM but faster, which Ryzen needs. If you want 32GB, it adds £73
INTEGRATED GRAPHICS ACCELERATOR (GPU)
1TB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W) Much faster than your SATA drive
CORSAIR 550W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET Higher quality power supply for longevity and efficiency
STANDARD AMD CPU COOLER Perfectly adequate
WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0 Much superior WiFI
Price: £678.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/kWzT2dA0WX/
I've made some upgrade on the above spec. I'd like to hear your opinion.
32GB Corsair VENGEANCE DDR4 3200MHz (4 x 8GB)
4GB NVIDIA GEFORCE GTX 1650 - HDMI
Microsoft® Edge
Standard Build - Approximately 9 to 12 working days
Price: £1,111.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/Z4raEJGp0U/
sck451
That's like an 80% budget increase!
I'm not sure you'll benefit from the 1650 unless you will be doing some gaming on the system. The 5600G's graphics are perfectly adequate for software development (and honestly even Intel's would be too). Why do you think you need it?
The RAM makes sense for certain kinds of development work, though it depends on what you're doing. (Compiling big software, sure; web development, definitely not.) Similarly the SSD: if you need 2TB, sure, though on a budget I'd be looking at a mix of SSD and hard drives, maybe 1TB of SSD and 2TB of hard drive.
The compromise I definitely wouldn't make would be to the power supply. Yes, 450W will certainly be enough, even with the 1650, but it will add cable clutter, add noise and reduce reliability, and reduce future use of the PC (if you decided to do some video editing, for example, and got a modern graphics card, 450W would be insufficient).
DarTon
If you want to spend more on a system with a discrete GPU but you will not be gaming, streaming or video editing etc, the right GPU cards are the T400/600 series. These are built purely to support multi-monitor productivity setups. They are quiet with low power consumption and a low profile. They use mDP (since it's a smaller form factor) but you can buy mDP to DP or mDP to HDMI adapters.
I'd also switch to Intel here over the 5600X since it's cheaper with the same performance. In terms of storage, have two drives to keep the storage drive separate from the drive for OS/main programs. If you need more storage add another M2 SSD yourself. 1TB is about £60.
Intel® Core™ i5 Six Core Processor i5-12400F (2.5GHz) 18MB Cache
ASUS® PRIME B660-PLUS D4 (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
PNY NVIDIA T600 - 4GB GDDR6, 640 CUDA Cores - 4 x mDP
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR | 1600MB/sW)
PCS FrostFlow 100 RGB V3 Series High Performance CPU Cooler
Firefox™
Price: £1,004.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/PaQgAD7GwA/
Thanks for your reply. I upgraded the gpu as I would like to develop software using CUDA. But then realised I dont need a high end GPU to play around with CUDA. All post 2008 GPUs from NVidia come with CUDA support.
Firefox™
This makes sense. Thanks a lot for your input.
sck451
Fair enough. I still have no idea what your budget is or what software development you're actually doing, though!
Pretty settled on the budget (i.e. ~1K +/- 10%) ... but don't want to spend on anything unnecessary (like fancy power supply or case) or any components that might become outdated soon. Will keep you guys posted.
So max budget is £1100? We can't really suggest anything without knowing a firm max budget.
